V-Belt Replacement - SailNet Community
post #1 of 5 Old 06-26-2012 Thread Starter
casey1999's Avatar
V-Belt Replacement
On a job today and some guys used this to fix a broken V-belt. Took 10 minutes. This repair belt has links so you do not need to remove other belts that might be in your way. Could be a fast way to fix a water pump belt or generator belt. Supposed to last longer than conventional v-belts. Good thing is you buy say a 6 foot length and you can keep using that to repair many different sizes of belts. (material comes in several belt widths). Could be a good thing in an emergency kit or for you delivery captains.
PowerTwist Plus V-Belts - Fenner Drives
casey1999 is offline
post #2 of 5 Old 06-26-2012
Familycruisers's Avatar
Re: V-Belt Replacement
We use those in the HVAC trade. They work well, especially in emergencies.
S/V Never Land
Westerly Centaur
Familycruisers is offline
post #3 of 5 Old 06-26-2012
Learning the HARD way...
eherlihy's Avatar
We used to use one of them on my friend's go-kart in the '60s... Worked like a champ. Where to buy though?
eherlihy is offline
post #4 of 5 Old 06-26-2012
SchockT's Avatar
Yeah I carry a length of that in my service van for emergencies, but you wouldn't want to use them instead of regular v-belts. Not only are they far more expensive, but they chew up the pulleys pretty quickly too.
You can buy them at any HVAC supplier.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #5 of 5 Old 06-27-2012 Thread Starter
casey1999's Avatar
Grainger has these, here is one size, Grainger has many more (search online):
http://www.grainger.com/Grainger/wwg...rue&sst=subset
Navico (Simrad) WP 300 CX drive belt replacement f8crusader1 Electronics 4 09-24-2016 08:45 AM
ST 4000 belt replacement wdtracey Irwin 6 10-17-2010 07:07 AM
Winterization in the Sun Belt bacampbe General Discussion (sailing related) 0 11-23-2009 10:44 PM
ST 4000 Belt Replacement beej67 Gear & Maintenance 5 07-14-2008 12:14 PM
A better V-belt? Valiente Gear & Maintenance 4 07-11-2007 08:41 AM
