Center & Align new Mast Bracket?!?? (with pics) - SailNet Community
post #1 of 5 Old 06-27-2012 Thread Starter
Hello,
I had posted a thread awhile back about cutting a mast since I was replacing the bracket (which was too big, cumbersome and a little bent up).
Quick Background:
I am replacing the mast step/bracket/cradle with a 'dwyer tabernacle'. I think it will work out nice. I will be able to use the factory holes (the other holes where drilled out crooked for the old bracket - this mast is a replacement and is not original to the step).
I grinded out most of the fiberglass where the step used to mount, it was cracked, had been drilled out a couple of times and discolored from water damage (this is a '74 laguna windrose)... thus I lost the original holes.
I am slowly rebuilding the glass from the inside upside=down one thin layer at a time, it's getting beefy, got about 20 layers up so far. Also plan to add 2 addition crossmembers and glass it all together. I will then glass a larger portion of the deck where the step mounts. I have not strated grinding top-side yet. The original holes are still there but there's a more than the originals (someone had this bracket off before and changed the holes a little).
My question is:
How do I center and align this new bracket??! Someone suggested I use a plumb bob and try to go off the center of the keel (which is not right under the mast). I want to get the bracket centered and also aligned so it's not cocked a little to one side of the other. Does the rudder come into play in the equasion? Also... is it ok to move the bracket forward slightly if the rigging allows (I want to center it over the crossmembers and wood inside the glass in the deck)?
Please help. This is my first sailboat project. I am thinking that you would want this straight and centered.
Thanks!
Shawn T
Wichita KS
MAST MOUNT (6).jpg   MAST MOUNT (5).jpg   MAST BOTH SIDES holes.jpg   MAST MOUNT (4).jpg   MAST MOUNT (2).jpg
Amateur_Expert is offline
post #2 of 5 Old 06-27-2012
Barquito
Barquito's Avatar
Re: Center & Align new Mast Bracket?!?? (with pics)
Me thinks moving the mast location would not be a very good first project. I gather the location of the old holes will not be helpful?
Valiant 32
Barquito is offline
post #3 of 5 Old 06-27-2012 Thread Starter
Thanks for the reply.
I just have the rear hole, the forward holes were lost with grinding. I know I can get close but was wondering if there is a way to make it true perfect. Since its a new bracket and new fiberglass I figured best to just re-measure (if possible) and drill new holes.
post #4 of 5 Old 06-29-2012
Barquito
Barquito's Avatar
I'm sure there is probably some trick way of doing this. My first thought would be to put a very tight rope from the stem fitting to the exact middle of the transom. If the one hole can be use to determine the fore/aft position then the rope with indicate athwartships position.
Valiant 32
Barquito is offline
post #5 of 5 Old 06-29-2012
tommays's Avatar
Thye dont even do that great of a job when the boats are new so i would thing the old holes you have and perhaps chacking with a tape measure that it is in the middle will be fine
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
CT 47 center cockpit, tall main mast, need line drawings dbraymer CT 11 01-02-2017 10:31 AM
Alt Bracket Turnbuckle? PorFin Diesel 1 05-16-2012 10:45 AM
Can I cut my mast? (with pics) Amateur_Expert Gear & Maintenance 20 05-07-2012 09:38 AM
Mast step bracket fills with water dhendry1316 C & C 1 05-07-2012 06:32 AM
Hole in Etchells Aluminum Mast, with pics. Seeking advice and ideas. GGman Gear & Maintenance 9 10-02-2007 09:28 PM
