VHF antenna - SailNet Community
Blogs
Old 01-14-2004
demetrik2 is on a distinguished road
VHF antenna
I installed a wire antenna at the top of my mast for my VHF radio. There is continuity between the wire antenna and the center wire of the coaxial cable, but also between the wire antenna and the outer (braided)wire of the coaxial. Does this sound right? Should the wire antenna be connected only to the center wire of the coaxial? Please advise.
Old 01-14-2004
joub is on a distinguished road
VHF antenna
If your antenna is a typical quarter wave whip i.e about 20" high, there should not be continuity between the braid and the center wire when the cable is disconnected from the radio. If the antenna is supposed to provide some gain then it''s possible that phasing stubs etc. could provide a path to the braid. Disconnect the co-ax from the ant and see if the short still exists. if it does, the problem is obviously in the coax. If you assembled the co-ax cable double check the connectors for a possible short. i.e. disconnect one connector and check, if still shorted, check the other end the same way.
There is always the possibilty of water contamination shorting out one of the connectors.
Also make sure no screws or sharp edges have cut into the co-ax.
Jim
Old 01-14-2004
obiec is on a distinguished road
VHF antenna
Some one a wile back was asking a very simalar question. The answer however was dramaticly diferent. The last person answering this question had a very good explanation and said that most will show a short. try looking back several pages.
gps antenna capedoryus Gear & Maintenance 3 01-07-2003 01:39 AM
DQ About Loran Antenna halyardz Gear & Maintenance 3 04-22-2002 03:50 PM
SSB Antenna windancer1 Gear & Maintenance 1 02-06-2002 07:46 AM
VHF Antenna billscat Gear & Maintenance 0 02-21-2001 05:13 PM
wtb loran antenna wolsen General Discussion (sailing related) 0 10-13-2000 06:53 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
