Powering AC with genreator, handling surge load - SailNet Community
 1Likes
post #1 of 15 Old 06-29-2012 Thread Starter
Hello,
I recently got a 2000 watt generator -- a little 2.7hp model. To operate it I simply plug a standard adapter which converts a standard 120v plug into a standard 30amp shore power plug into its 120v and hook my shore power cable into that adapter, and into the shore power socket. It works great, and powers everything BUT the AC. My AC is 16000btu, and draws a modest 4-5 amps under running condition (4-5amps*120v should be around 600 watts, P=IV), however, when the compressor kicks on it draws between 15-30amps. This is no problem on shore power but this surge is beyond the generator's capacity and it cuts out.
I realize I could go to a larger generator, but I do not want the additional weight nor size.
I was wondering if I could run power to the shore power in parallel -- one side of the circuit coming from the 2000 watt generator, and the other coming from a 2000-4000 watt inverter attached to the deep cycles. I theorize that when the AC kicks on, it will draw additional current from the battery to deliver the the necessary amps to kick on the compressor, and then when it drops down to running level amps (4-5amps) I can simply disconnect/switch off the inverter from the batteries, allowing the generator to carry the load on its own for the rest of the time.
Is this feasible? Has anyone experimented with a similar setup?
Thanks!
xluke is offline
post #2 of 15 Old 06-29-2012
Once known as Hartley18
Classic30's Avatar
Dock
Re: Powering AC with genreator, handling surge load
Is this feasible?
No, no, NO - absolutely not! You can't practically parallel up to shore power without fitting large and expensive control gear.
The only way you could get your A/C unit to work off of the generator you have will be to install an Inverter big enough to handle the current in-rush of, as you said, 15-30 Amps ie. 30A*120V = 3600 watts, and run that off a battery which you charge with the generator. The A/C would be running off the Inverter full-time. I don't know what a 4kW Inverter would cost, but it wouldn't be cheap - or light - but, by the sounds of it, that's what you'll need.
IMHO you are better advised to get a bigger generator.
Classic30 is offline
post #3 of 15 Old 06-29-2012
I've read a number of posts about a "soft starting" AC. I don't know the details but it is some kind of option you can add to the AC unit that makes it pull a lot less amps when starting up. A number of people have it just for your purpose - they have a fairly small generator that works fine except for compressor start up.
Catalina 34
chuck53 is offline
post #4 of 15 Old 06-29-2012
JimsCAL's Avatar
Hartley is absolutely right about not paralleling two AC sources. To do this you need synchronizing controls so the sine waves are in synch. Without that you will get excessive current and damage things.
And something is wrong with your number for AC capacity or normal current reading. Typical EER of an AC unit is 10. So a 16,000 Btu/hr unit would draw about 1600 watts. That's close to the rating of your generator and will never be able to start it. A 6000 Btu/hr AC unit would be about 600 watts and that would agree with your 4-5 amps when running. Check your numbers.
JimsCAL is offline
post #5 of 15 Old 06-29-2012
I'm betting the 4-5 amps is just the fan running by itself - no compressor.
Catalina 34
chuck53 is offline
post #6 of 15 Old 06-29-2012
One of None
deniseO30's Avatar
PO needs to get a real time amp reading on the unit when it starts. The fan most likely runs on less the 2 amps. Depending on which compressor (recip or rotary) will dictate starting amps. if the unit doesn't have a "hard start" accessory. it will need it to lower the starting amps. Do not use the name plate rating for ACTUAL running conditions. I'm assuming the unit is water cooled? That would also make the unit a lower amp draw then a air cooled condenser.
My last project!
deniseO30 is offline
post #7 of 15 Old 06-29-2012
Stu Jackson's Avatar
That's the way to do it. Never, ever combine two different incoming AC electrical sources. Never.
Google "soft start for boat air conditioning" and you'll find the sources.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #8 of 15 Old 06-29-2012
Depending on which small gen you bought, the Honda and Yamaha can be linked to produce a nominal 4kw from two 2kw gens. But this only works because the control boards can talk to each other and sync up by a cat5 cable.
Trying this with dissimilar sources, as noted above, is both dangerous and a fire hazard.
Greg
Stumble is offline
post #9 of 15 Old 06-29-2012
One of None
deniseO30's Avatar
Back in the day cities in the east like Phila pa. Had and and may still have some "2 phase" service. There used to be 2 phase wired BIG semi hermetic compressors in some old ac units.
Just for conversation, and some interesting reading
http://www.3phasepower.org/2phasesystems.htm
My last project!
post #10 of 15 Old 06-29-2012
tommays's Avatar
They still have the two phase and the big machines get special motors which is a PITA
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Surge currents in Marina del Rey!? dnickers General Discussion (sailing related) 11 03-14-2011 08:08 PM
Storm/Flood Surge, Hows it looking? T37Chef Chesapeake Bay 28 10-04-2010 03:44 AM
Surge and Die Snboard976 Diesel 7 06-27-2010 07:23 PM
Sea Surge theartfuldodger Cruising & Liveaboard Forum 16 02-14-2010 05:09 PM
Surge Protection Question matt2 Electrical Systems 1 03-02-2009 12:36 AM
