Kiwigrip advice needed - SailNet Community
 1Likes
post #1 of 37 Old 06-29-2012 Thread Starter
Senior Moment Member
SloopJonB's Avatar
I have a question for anyone experienced in using Kiwigrip non-skid.
Is it thick enough to fill in and cover a typical worn non-skid pattern or must you first sand off all or most of the raised pattern in order to get a good looking finish?
SloopJonB is online now
post #2 of 37 Old 06-29-2012
Re: Kiwigrip advice needed
I'll add a question for those experienced with it... is it also suitable for the non-skid seating surface areas in the cockpit?
In my research I've seen the vendor says one's roller technique can create more-or-less stipple... but I'm curious to hear peoples' real-world experience.
hriehl1 is offline
post #3 of 37 Old 06-29-2012
Over Hill Sailing Club
smurphny's Avatar
Sloop, I did all my decks with Kiwi three years ago, right after recoring the decks. Am very satisfied with the way it has held up, even up where it gets the most hard use up near the anchor. It is the consistency of mayonnaise. You can control the amount of texture by the kind of roller you use. They supply a roller that leaves a VERY rough surface. When I go over it again will find something a bit less aggressive. It dries fast, so it is best to have two people- one spreading to a uniform thickness, one texturing. A small pc of the roller is necessary to get in under stuff where the roller will not reach. Taped edges need to be pulled before it sets completely or the tape will lift the edge. I don't know how deep your existing tread is but the Kiwi is much thicker than a regular paint. I CAN see where the old non-skid lines were if I look for them where I went below the radii on the corners of the cabin top so as to eliminate them as slip zones.
I would not use it for seating areas. It's too rough. The only place I used it in the cockpit is under foot. A bit of warning- the stuff is really rough. It's perfect for my taste but would take your skin off readily if you fell on it. With kids around, I'd be wary of making it too rough.
smurphny is offline
post #4 of 37 Old 06-29-2012 Thread Starter
SloopJonB's Avatar
Thanks Smurph - see the highlight - I read that as saying it WON'T completely cover or rather bury the old moulded non-skid pattern.
Is that correct? I'm not so much concerned with the final texture as with whether or not I will need to sand my whole deck completely smooth before applying it.
I have a flush deck 43 footer so it's a BIG deal to me.
post #5 of 37 Old 06-29-2012
aeventyr60's Avatar
I think you need 80 grit smoothness. The application of and resultant finish can be affected by thinning the kiwigrip and or using a different "stipple effect" roller. My painter used a different roller in the high wear areas to provide better traction and wear. As a filler I don't think I'd want to rely on the kiwi grip. I've had it on the deck for 7 years now. Glad I took the time for proper surface prep first. Can understand the 43 feet of deck challenge......gonna have some guns after that job!
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #6 of 37 Old 06-30-2012
On the hard
CharlieCobra's Avatar
You control the texture by controlling the thickness. 1/8" inch will yield a very stippled surface. 1/16" or less will give that small texture for cockpit seats or coaming tops that ya want. It will cover old non-skid nicely. Just use a paint eater or other scotch brite wheel to give the old non-skid some teeth for the Kiwi Grip to latch onto.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #7 of 37 Old 06-30-2012 Thread Starter
SloopJonB's Avatar
Thanks Charlie - I will have to sand and I figured on a 50 or 60 grit on an R/O - I just didn't want to have to completely sand off all the raised pattern as it would be a huge job.
post #8 of 37 Old 06-30-2012
72 C&C Corvette
CorvetteGuy's Avatar
used it on the topside of ma Corvette went right over the original molded nonskid and it did cover the pattern, I put it on my cockpit but we use cusions, it can also be sanded down gently for a not so aggresive feel. heres a pic of end result. very happy with the ease and price!!
CorvetteGuy is offline
post #9 of 37 Old 06-30-2012
72 C&C Corvette
I also preped the deck with a bronze wire wheel and a cordless drill. scratched it up just fine.
post #10 of 37 Old 06-30-2012 Thread Starter
SloopJonB's Avatar
Looks very nice. Is that grey straight out of the can or did you mix grey & white?
It looks paler than the samples of grey that I saw - they were much more "battleship" toned.
Non skid - Kiwigrip need some input patrscoe General Discussion (sailing related) 5 07-01-2011 08:11 AM
Advice needed Sixpoint General Discussion (sailing related) 11 05-05-2011 12:21 PM
KiWigrip, too good to be true? deniseO30 Gear & Maintenance 9 06-04-2010 01:28 PM
kiwigrip photos at last nightowle Gear & Maintenance 15 11-19-2008 08:52 PM
Help! Advice needed. PalmettoSailor Gear & Maintenance 5 06-25-2008 04:48 AM
