07-03-2012
Senior Pirate
Re: 2GM20F Starting?
Although I agree that an air leak causes hard starting, it also makes for a rough running engine. .... So...This will make the third answer suggesting you adjust the valves. This is a real easy procedure, will only cost the price of a valve cover gasket and you'll be done in 10 minutes.
Tropic Cat
