Adhesives for flexible PVC (Plasteak) - SailNet Community
post #1 of 5 Old 06-30-2012 Thread Starter
Irunbird's Avatar
I'm in the process of replacing the trim on my Olson 30 with Plasteak and I didn't think to ask them about adhesives (since I'm bolting most of it in place). I'm thinking of sealing at least the stern toe rail with a bead of something, but not sure what would actually adhere to this stuff.. it seems rather slippery. I'd rather avoid 3M 4200, but would a polysulfide (like Lifecaulk) work, or maybe plain old silicone?
Irunbird is offline
post #2 of 5 Old 06-30-2012
Re: Adhesives for flexible PVC (Plasteak)
Plumbing adhesive for PVC pipes. Two part system, 1st part cleans and primes the surfaces, 2nd part is an adhesive that welds the two pieces. Clamp the two pieces for a few minutes and it is done.
Just be careful as the primer/cleaner will leave a purple surface stain.
Try it without the primer?
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #3 of 5 Old 07-01-2012
minnow1193's Avatar
There is clear primer available, just have to look for it. Also white cement available for pvc fencing that does not require a primer.
minnow1193 is offline
post #4 of 5 Old 07-02-2012
Sailor
Gladrags1's Avatar
Are you referring to using the caulk between the Fiberglas and the plasteak to supplement the fasteners? You are looking for something to stick to Fiberglas and plasteak. Just wanted to be sure; I don't know the answer either.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #5 of 5 Old 07-02-2012
This is well worth reading especially the section on rebedding beck hardware.
Compass Marine "How To" Articles Photo Gallery by Compass Marine at pbase.com
bandaidmd is offline
CDI Flexible Furler dbruce85 Gear & Maintenance 2 04-11-2011 10:19 AM
Flexible Fuel Tanks? danielgoldberg Gear & Maintenance 19 12-31-2009 06:37 PM
Flexible Coupling & grounding trantor12020 Gear & Maintenance 5 06-08-2009 08:42 AM
Flexible Couplings trantor12020 Gear & Maintenance 6 09-19-2008 06:28 AM
CDI Flexible Furlers joub Gear & Maintenance 5 05-27-2001 04:13 PM
