the "vent" on a vented loop - SailNet Community
 1Likes
  • 1 Post By ebs001
post #1 of 8 Old 07-03-2012 Thread Starter
Question the "vent" on a vented loop
Is there a name for the little valve thing that goes on top of a vented loop? I can find vented loops for sale, but not just the little piece that goes on top, and I wonder if I'm just not using the right search term. I'm in the middle of replacing my head (perhaps the most horrible thing I have ever experienced), and I would like to reuse my existing vented loop since it's in nearly perfect condition, but the little valve needs replacing.
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #2 of 8 Old 07-03-2012
ebs001's Avatar
Re: the "vent" on a vented loop
Try here Forespar MF-841 Replacement Duck Bill / Cap Assembly
erps likes this.
ebs001 is offline
post #3 of 8 Old 07-03-2012
the pointy end is the bow
erps's Avatar
YAY! Those little duckbill valves are on my list of spares that I want to have on board, although you could probably get by with cleaning it and maybe softening it with lube or something.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 8 Old 07-03-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Now that is excellent. I've always presumed that the things were only sold as complete units which is annoying when it is usually the valve that misbehaves and that is the easy bit to replace.
Thanks Ebs.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #5 of 8 Old 07-05-2012 Thread Starter
I think this thing is more like what I need (similar product with a hose barb on top). Unfortunately, it has a 1/4" barb, and the existing vent system, some of which is being reused, is all 1/2". Now I've got some search terms to play with though. Thanks!
rmeador is offline
post #6 of 8 Old 07-05-2012
For the intake line , some just burn a hole in the platic tubing, with a hot nail, at the high point of the loop, then put their finger over it while pumping. Its intake water ,so it's clean.
Brent Swain is offline
post #7 of 8 Old 07-06-2012
Maine Sail's Avatar
Does it look like this?
If so they are made by the Scot Pump Co. and you can buy just the vacuum breaker. I think the part number is VB-18....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #8 of 8 Old 07-06-2012 Thread Starter
Maine Sail, yes it does look much like that white "siphon break" part on the top, but the loop is a continuous piece of stainless, not two elbows and a T. The Forespar valves ebs001 found are exactly what I need, but unfortunately won't fit the loop, so I bought a new Forespar vented loop complete with vent. I'm not going to bother to vent overboard with the new install, seeing as someone pointed out it only sucks air in, so no sewage smell should escape (the holding tank will still vent overboard, of course). Thanks for your help.
rmeador is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
