Remove Diesel Smell - SailNet Community
post #1 of 10 Old 07-04-2012 Thread Starter
Remove Diesel Smell
Anyone know a good way to get rid of diesel smell? Diesel's been in the bilge for quite a while. Everything has smell of diesel; cushions, clothes, woodwork, canvas, etc.
thanks for any and all help
capsss is offline
post #2 of 10 Old 07-04-2012
jsaronson's Avatar
Re: Remove Diesel Smell
lay the cushions and canvas in the sun. Febreeze.
jsaronson is offline
post #3 of 10 Old 07-04-2012
One of None
deniseO30's Avatar
Did you fix the leak? Look for a heating and AC supplier in your area if they sell supplies to the fuel oil trades people they would have a spray that will kill the smell.
My last project!
deniseO30 is offline
post #4 of 10 Old 07-04-2012
Stu Jackson's Avatar
Odor eliminator PureAyre eliminates cat, pet, smoke, skunk, cigars, gasoline, cooking and musty odors.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 10 Old 07-04-2012
Irrationally Exuberant
PurAyre does a decent job. I think it and KidsNPets and Febreeze work similarly, using enzymes to break down molecules.
As you've noticed the smell gets in everything. Which means you need to get the smell out of everything. But go for the source first. Eliminate any diesel leaks, maybe even replace really old diesel fuel lines if they smell. Then clean the bilge really well. I like the citrus type bilge cleaners. Then go after your surfaces and finally all the soft stuff.
BTW, to finally eliminate the odor in our boat, I had to soak wash all the cushion foam and then soak the foam in an odor eliminator solution (KidsNPets was my choice at the time) and dry them out. Foam holds a whole lot of smell in those millions of pockets and just washing the covers won't do it.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #6 of 10 Old 07-04-2012
Calgone water softener works.
Brent Swain is offline
post #7 of 10 Old 07-07-2012
I took all my cushions to my local carpet and furniture cleaner. He cleaned them twice and let them dry out. So much nicer now
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #8 of 10 Old 07-07-2012
first get the diesel out of the bilge
sck5 is offline
post #9 of 10 Old 07-07-2012
1- Remove the diesel from the bilge.
2- Get a bag of quick dry oil absorb or if you can't find any use kitty litter and empty the whole thing into the bilge and where ever the diesel was.
3- Let that sit for at least a day, then remove it.
4- Scrub the entire area with pure bleach.
I've dealt with many oil spills in customers basements and this seems to work the best.
Freerider is offline
post #10 of 10 Old 07-08-2012
Everything is a waste of time and money until you remove the diesel which has soaked in, and afterwards seal any porous surfaces which may still contain diesel.
In between? Heat, sunlight, ozone, ventilation all help drive it out, but it also takes TIME because you're trying to get some very 'sticky' molecules out of materials they have had a good time bonding with. And of course a good scrubbing with something that can remove oils (like Liquid Tide detergent) to make sure it is all cleaned off the surfaces, before you reseal them.
hellosailor is offline
Any good diesel smell solutions teflongeoff Cruising & Liveaboard Forum 18 06-12-2011 07:40 AM
Diesel smell in clothes brokesailor General Discussion (sailing related) 17 11-15-2010 08:29 AM
Diesel Smell After Spill labestia Gear & Maintenance 12 07-31-2009 01:30 PM
Wallas stove-oven diesel smell ? SvenG Gear & Maintenance 6 02-11-2009 03:04 PM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 09:00 PM
