Sticky mainsail - SailNet Community
 1Likes
  • 1 Post By BarryL
post #1 of 7 Old 07-05-2012 Thread Starter
Question Sticky mainsail
Most sailboats that I've been on have a mainsail that drops quite easily when the main halyard is released. On my boat I have to tug constantly and firmly to get it down. The mainsail is the type with runners attached to the luff which ride up and down a slot in the mast. Is there a marine silicone that can be sprayed onto the runners that will help them slide better or any other suggestions?
tspooner is offline
post #2 of 7 Old 07-05-2012
One of None
deniseO30's Avatar
Re: Sticky mainsail
Yes there a few sprays on the market for that. You may also want to make sure you have the right slides, sometimes people have the wrong ones and don't know it. You halyard may be hanging up also.
My last project!
deniseO30 is offline
post #3 of 7 Old 07-05-2012
BarryL's Avatar
Re: Sticky mainsail
Hey,
The stuff I use is called 'Sailkote' and it works very well. My mast comes down in the fall for winter storage. In the spring I spray the sail track liberally and the sail goes up and down very easily. Mid way through the sailing season it starts to slow down. I spray as much of the track as I can and that helps.
Good luck,
Barry
johnnyquest37 likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #4 of 7 Old 07-05-2012
Re: Sticky mainsail
Second on the Sailkote. Good stuff works well even if you just spray the sail slugs. You might also want to go up the mast and check the shivs(sp) at the top of the mast, if damaged that could also create similar problems.
Peter
justified is offline
post #5 of 7 Old 07-05-2012
marcusc130's Avatar
Sticky mainsail
Make sure your main sheet and outhaul are eased as well. They can put pressure on the slides if they are tight.
marcusc130 is offline
post #6 of 7 Old 07-05-2012
Barquito
Barquito's Avatar
Re: Sticky mainsail
Someone posted a method for spraying the slot by pulling a can up on a halyard. Don't remember how it was done.
Valiant 32
Barquito is offline
post #7 of 7 Old 07-05-2012
swimnfit's Avatar
Re: Sticky mainsail
I squeezed a small wad of cloth betwwen the first two lugs that go up the mast. I then staurated the cloth with SailKote (Super Good Stuff BTW). Then, as the sail is raised and lowered it lubricates the track. I will occasionally re-apply as needed.
I have also heard of cutting small pieces of Dove soap from the bar and wedging into the track to clean and lubricate the same way. Leaves a little soap when it rains though.
ďA wet sheet and a flowing sea, / A wind that follows fast / And fills the white and rustling sail / And bends the gallant mast.Ē
swimnfit is offline
sticky hull davidpm Gear & Maintenance 6 05-28-2012 09:30 AM
sticky traveller Bene505 Gear & Maintenance 7 07-16-2009 02:14 AM
Sticky Mainsail Slides/Slugs backcreeksailor Gear & Maintenance 11 05-25-2009 09:50 PM
Sticky Mainsail sun37 Gear & Maintenance 22 06-13-2008 08:45 AM
Sticky Tachometer maboyer Gear & Maintenance 2 11-20-2007 12:22 PM
