When is the best time to check oil? - SailNet Community
 1Likes
post #1 of 15 Old 07-05-2012 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
When is the best and most accurate time to check the oil on a marine diesel?
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #2 of 15 Old 07-05-2012
DrB
About 10 minutes or so after the motor is off and the motor......
was at full operating temp.
Hot oil has more volume than cool oil. You need to wait about 10 minutes after the motor is shutoff to allow it to full drain back into the pan. Measuring cold oil won't give you the true oil volume.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #3 of 15 Old 07-05-2012
After oil change when engine is cold, and oil is full, check dip stick. That's your full level, engine cold. Thereafter, check with cold engine.
miked is offline
post #4 of 15 Old 07-05-2012
Also, if you are low, it's easier to add oil to a cold engine.
miked is offline
post #5 of 15 Old 07-05-2012
Junior member, rest old
msmith10's Avatar
Re: When is the best time to check oil?
also, you should routinely check oil level before starting engine. That means it's gonna be cold.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #6 of 15 Old 07-05-2012
DrB
Disagree somewhat with responses
The OP asked when is it the best and most accurate time to check oil on marine diesel. I stand by my advice to check it when the engine/oil is warm.
My procedure when I change my oil is to:
  1. Run motor for 10+ minutes.
  2. Allow to cool 10-20 minutes
  3. Suck out/drain oil.
  4. Change filter.
  5. Refill with cold oil to about 3/4 mark.
  6. Turn on motor and allow to circulate for 5 minutes to warm oil and fill filter. Motor is still warm from previous operation.
  7. Recheck oil level and add oil until just below top level mark.
About every 10 h of motor running. I recheck the oil. Usually do while it is cold and add oil if necessary, but only add to ~ 3/4 level. Adding too much oil can be a real mess and cause an over flow.
DrB
DrB is offline
post #7 of 15 Old 07-05-2012
msmith10's Avatar
Re: Disagree somewhat with responses
DrB
Wasn't disagreeing with you. Just reinforcing that oil level should always be checked before starting the engine. One of my rules, like always checking for water flow from the exhaust. Obviously, I don't check oil level when finished sailing and coming into harbor, but I do check it before going out.
Mark Smith
msmith10 is offline
post #8 of 15 Old 07-05-2012
bljones's Avatar
Whatever your manual says. Yanmar manual specifies before starting, IE cold.
It's 5 o'clock somewhere:
bljones is offline
post #9 of 15 Old 07-05-2012
DrB
Agree
Simplest to check before you start (engine cold), as you state and I do also. The OP just needs to be aware that the hot oil will have more volume than cold oil, so filling an engine the upper limit level, with cold oil, my lead to issues when it has expanded to it's hot volume.
When I bought my replacement filter and changed my oil on my Yanmar (3GM30F) the first time, the Service guy made it a point to let me know to not to over fill the motor and only add a maximum of 2 quarts of oil cold when refilling, even if it said I should fill more, and then run engine. He said after the oil warms up, then check the dipstick add a more only if necessary. Advice I have heeded.
DrB
DrB is offline
post #10 of 15 Old 07-05-2012
bljones's Avatar
Checking cold means you get an accurate dipstick read. Oil volume does not increase dramatically enough to offset the amount of oil still returning to the pan after running to make a post- run, still -warm test any more accurate.It may take an hour for a thicker weight oil to return to the pan. in fact, it may be exactly the opposite, since the dipstick is calibrated for cold volume in addition to cold capacity.
bljones is offline
Tags
check , checking oil , diesel
Long-Time Sailor, First-Time Pearson Owner edwardc Introduce Yourself 7 06-29-2016 12:11 AM
long time sailor 1st time intro fstued1 Introduce Yourself 2 10-27-2010 10:08 AM
First time Owner... First time Poster... mtmd Introduce Yourself 0 06-25-2008 04:17 PM
Regatta Time Is Party Time in the Abacos Doran Cushing Racing Articles 0 07-25-2000 08:00 PM
