Dinghy Painter: Float or Sink? - SailNet Community
 1Likes
post #1 of 12 Old 07-05-2012 Thread Starter
For the second time (in twenty years) I cut my dinghy painter with the prop on the bigger boat. I should have shortened it up before starting the motor, I didn't. I quickly realized my mistake, stopped the engine, recovered the dinghy (crew grabbed it) and anchored. Engine off in nuetral, the remaining line was just pulled free.
I've always used a floating line to secure the dink, berlieving that will keep it out of the prop. When docked, my docklines hang from pilings, straight down onto the water, not floating. They don't get in the prop, the dinghy line does. Maybe I'm doing this wrong. If the painter were nylon, it would hang staight down, mayber avoiding the prop? Or will it suck in anyway? What are your experiences?
WanderingStar is offline
post #2 of 12 Old 07-05-2012
HANUMAN
RobGallagher's Avatar
Re: Dinghy Painter: Float or Sink?
It should float or not be long enough to foul the prop.
I have two set ups. The only time I use the longer one (that can foul the prop) is when I'm towing long distances. I don't let it out until the sails are up and I'm on my way.
To the dock, about the mooring field or whatever, it's a short painter that cannot foul the prop and can double as a dock line for the dink.
RobGallagher is offline
post #3 of 12 Old 07-06-2012
Sailor
Gladrags1's Avatar
You should never have lines in the water around the boat when you are using the motor. It invites trouble and the fact that it has only happened twice in 20 years is amazing. Use a poly mix line for your dinghy's painter so it floats or put floatations on the line to keep it from sinking. A line that winds itself around the prop and then jams it, stalling the engine, can do damage to the drive train. You could also hit the object you are using the engine, now stalled, to avoid and in windy conditions you might do damage.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 12 Old 07-06-2012 Thread Starter
Thanks.
Maybe I wasn't clear. The line does float and still got sucked into the prop. I know it should be short, that's why I stated that I forgot to do so.
post #5 of 12 Old 07-06-2012
Sailor
Gladrags1's Avatar
Yes, I saw that but was speaking more generically. I used to cut up a noodle and place sections of it along the painter to help keep it afloat. That way it would be more difficult to run over the line, forcing it down into the prop as you back up under higher rpm's.
Mandolin
Bayfield 36
post #6 of 12 Old 07-06-2012
I like the cut up noddle idea!
I have a floating painter and always shorten it when docking...that way no chance in it getting into the prop.
DWT1 is offline
post #7 of 12 Old 07-06-2012
Siamese's Avatar
Ditto on the floating line and shortening it. This year I added a cleat at the stern, just for the dinghy. Easy to adjust the length right from the helm.
Siamese is offline
post #8 of 12 Old 07-06-2012
bljones's Avatar
float and keep an eye on the painter. better yet, use a short bridle attached to the transom of the dinghy and hoist it so it is towed backwards, just aft of the mothership.
It's 5 o'clock somewhere:
bljones is offline
post #9 of 12 Old 07-06-2012 Thread Starter
Maybe I'll add some floats.
I guess no one has tried one that doesn't, at least since synthetic line.
Thanks.
post #10 of 12 Old 07-06-2012
Wandering Star,
we have a dinghy painter that is not a floating line and have not yet caught it in the prop. So far we have remembered to shorten it or just been lucky!!! However we have another 14 years of sailing to catch up to you!
Regards,
Tanya
WanderingStar likes this.
tjvanginkel is offline
towing a dinghy, Painter size? Cruiser2B General Discussion (sailing related) 19 09-17-2011 02:04 PM
dinghy painter floats? Joesaila General Discussion (sailing related) 4 05-31-2010 06:35 PM
Who has done it - run over your own dinghy painter Zanshin Seamanship & Navigation 20 12-23-2009 05:27 PM
Painter attaches to where? stu9000 Gear & Maintenance 0 06-21-2008 06:19 AM
Looking for Topsides Painter NewsReader Mass Bay Sailors 0 06-11-2007 11:15 AM
