New Dripless! What else should I check while hauled out? - SailNet Community
post #1 of 6 Old 07-05-2012 Thread Starter
itsaboat's Avatar
Had the marina haul the boat (27' Pearson full keel) out today and a buddy and I finally replaced the perilous old stuffing box with a PSS Dripless. Everything went smoothly and we were done in 6 hours. See the before and after pics attached or head over to Main Sail's site for another view.
While the boat is out, I am going to replace the depth and speed through hulls. That will be tomorrow in the 102 degree heat, a break from the 106 degree heat we have had lately.
The cutlass bearing has been "squealing" and has been giving some resistance to the little 7.5 horse diesel. I did not know the source of the noise until we hauled out and the shaft was hard to turn and the cutlass bearing squeaked when turning. There is no play in it, so is this a problem? We hit it with some silicon spray and that helped. I figure it will wallow out eventually.
Is there anything else I should check while the boat is on the trailer?
Pearson 27
itsaboat is offline
post #2 of 6 Old 07-05-2012
Junior member, rest old
msmith10's Avatar
Re: New Dripless! What else should I check while hauled out?
Did you check engine alignment? Separate the prop shaft coupler from the transmission output flange, then slide them back together but don't bolt them down. Are they lined up circumferentially? If so, put a feeler gauge at 12, 3, 6 and 9 o'clock. You shouldn't have more than .001 clearance difference per inch diameter of shaft coupler diameter. In other words, if your shaft coupler is 3" in diameter, you shouldn't have more than .003 clearance at any of the above spots. This is a simplified instruction, but start there.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 6 Old 07-05-2012
orientalnc2010's Avatar
If the shaft is hard to turn then I would suspect that the engine is not aligned properly. Now that you have the PSS installed you will have to use two feeler gauges to check the coupling to the transmisson flange. One as a shim to hold the flange and coupling apart and the other gauge to check the gap.
If you have the correct alignment then the shaft should turn free and not squeal. If this does not help then.... Did you happen to notice if your shaft was centered in your stern tube when you had things apart? The stern tube and cutlass need to be in the same plane or in line with each other and maintained that way when messing with the engine mounts.
Once you have the boat back in the water check the engine alignment again.
Hope this solves your problem.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
orientalnc2010 is offline
post #4 of 6 Old 07-05-2012 Thread Starter
itsaboat's Avatar
Clarification. The prop shaft squeaked in the cutlass bearing whether it was attached to the transmission or not. It just seems tight.
We did not check the feeler gauge clearance. I can loosen the bolts and do that while it is out. Good suggestion. Question is what do I do if the alignment isn't right? Adjust the engine mount settings?
Pearson 27
itsaboat is offline
post #5 of 6 Old 07-05-2012
msmith10's Avatar
This is a quick summary: this all assumes the shaft coupling is square on the shaft and the shaft is straight (not a safe assumption).
If there's a gap when you check with the feeler, rotate the shaft 180 degrees. If the gap moves to the opposite side then the assumption is wrong. If the gap stays in same place proceed as follows
1) Shim or block the propshaft so it is centered in the shaft tube.
2) Shift the engine right or left until its centerline is lined up with the centerline of the shaft and the gaps on the left and right sides are roughly equal.
3) Raise or lower the rear of the engine until the center of the engine coupling is close to the center of the shaft coupling.
4) Raise or lower the front of the engine until the gap is even and minimum all around the coupling
5) Repeat steps 2-4 as necessary until the gap all around is less than 0.003".
6) Remove the shaft centering shim/block.
Mark Smith
msmith10 is offline
post #6 of 6 Old 07-07-2012 Thread Starter
itsaboat's Avatar
Thanks for the detail. I will check it out.
Pearson 27
itsaboat is offline
Alternative to being hauled up the mast? jaschrumpf Gear & Maintenance 30 05-26-2009 10:21 AM
First time I've hauled out... Coreyboy18 General Discussion (sailing related) 7 02-11-2009 01:29 PM
Since You Have Hauled it Out, You Might As Well ........... LittleWingCA Gear & Maintenance 30 09-09-2008 09:55 PM
The optimum close hauled to close hauled tack davidpm Racing 20 07-08-2008 07:23 AM
Close hauled traveler use lharmon General Discussion (sailing related) 6 02-16-2008 08:00 AM
