water pressure problems - SailNet Community
 1Likes
post #1 of 13 Old 07-06-2012 Thread Starter
patrscoe's Avatar
Can't seem to figure out our water pressure system problem and unfamiliar with a sailboat water pressure system.
What the system is doing:
- Water spits and sputters at all water faucet locations and not holding pressure. Pump is getting hot so we shut it off.
We do see water entering the line into the pump, fresh water tank is full and the valve is on at the tank and there appears to be no other valve within the system.
Perhaps there is air in the lines? Not sure how to bleed the lines.
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #2 of 13 Old 07-06-2012
Tim R.'s Avatar
Re: water pressure problems
Is this a new boat to you?
Most owners will drain the HW tank and leave the valve open.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #3 of 13 Old 07-06-2012 Thread Starter
patrscoe's Avatar
yes, purchase this past winter and was on the hard until a few months ago and have not used the pressure water system until this week.
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #4 of 13 Old 07-06-2012
Patrick
Also check if there is a filter on the water system you my be picking air up there.
peter
justified is offline
post #5 of 13 Old 07-06-2012
Tim R.'s Avatar
Talk to the PO if possible. If not, you will need to trace all your lines to see if you are missing something. It is also possible that the air in your HW tank is not being bled. Try running only hte hot water faucet. It could take a while to bleed. Maybe 5-10 minutes. If the pump gets hot, shut it off and lett it cool and continue.
Check your bilges to see if the water level is increasing.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #6 of 13 Old 07-06-2012
johnnyquest37's Avatar
There should be a fresh water filter on the inlet side of the pump. That filter may be clogged.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #7 of 13 Old 07-06-2012
Usually all that's necessary to bleed, is to turn off the pump, open all the faucets, and fill the tank to the brim. The top of the filler is the highest point in the system so will act as the priming point. Keep the hose running (doesn't matter if it's overflowing a bit over the deck) until water flows air-free from the taps. NB, if the bilge pump goes nuts at this point, that's telling you there's a leak. Go find it now, while it's leaking.
MarkSF is offline
post #8 of 13 Old 07-06-2012
Patrick,
You might just have a small diaphragm pump. Some of these will mimic air in the line due to the on/off nature of the water flowing through them. It could also be that the pump is getting hot from the hot water flowing through it, not a pump problem.
Try running it with cold water, if it still overheats, you probably need a new pump.
Greg
Stumble is offline
post #9 of 13 Old 07-06-2012
check if you have an in line filter for the water...mine was plugged and letting very little water through...and I had similar symptoms as what you describe.
johnnyquest37 likes this.
simpsoned is offline
post #10 of 13 Old 07-06-2012
travlin-easy's Avatar
My guess: I encountered the same problem. The solution was simple: 1st, if you have both manual and electric pumps using the same line, you must have cut-off valves on the lines to the hand pumps. If not, the electric pump will suck air back through the valve(s) of the hand-pumps and into the electric pump, thus causing the electric pump to loose it prime and overheat. Once I closed the hand-pump shut-off valves, the electric pump put out all the pressure you could ask for.
Good Luck,
Gary
travlin-easy is offline
Pressure Water, Black Grit WanderingStar Gear & Maintenance 7 07-03-2010 07:45 AM
Water Pressure Puzzel cvsheppard Gear & Maintenance 11 06-01-2010 08:21 PM
Commisioning the pressure water system bkupmstr Gear & Maintenance 7 04-29-2009 12:34 AM
Fresh water pressure, help nauticalrich Gear & Maintenance 5 07-28-2003 06:11 AM
Oil Pressure Problems Tom Wood Gear and Maintenance Articles 0 05-16-2002 08:00 PM
