OOP'S I think I ran out of fuel !!!! - SailNet Community
 1Likes
  • 1 Post By Capt. Gary Randall
post #1 of 3 Old 07-07-2012 Thread Starter
Capt. Gary Randall's Avatar
Most smaller diesel engines operate on a CAV high-pressure fuel distributor pump, however in this case we are going to specify Perkins engines 4-108, 4-236,6-354. you may have run out of fuel or you may have fuel filter problems. In either case your engine is not going to start. You need to be very wise with battery power, and even if you did run out of fuel it is probably wise to put new fuel filters on anyway..
BLEEDING the fuel system..... all high-pressure pump's have a bleeder screw on the side of the pump. You also have a manual lift, pump that you can pump by hand without cranking the engine. Number one, change your filters both primary and secondary, after you remove the old filter,Prime the new filter with fresh diesel fuel,install the filters.make sure you have fuel in your fuel tank. next on the secondary filter (the little one) you will see a pipe fitting on the very top of the filter you need to loosen this. Next ,pump the manual lift,pump until clean fuel bleeds out with no air.. Retight the pipefitting on top of the little fuel filter. Look on the side of the fuel disturber,pump you'll see a quarter-inch bleeder screw a 5/16 or 1/4 box end wrench should fit. Loosen the screw about three turns. Pump your hand lift pumpuntil clean fuel comes out with absolutely no AIR. tighten the Bleeder screw. Pump the hand lift Pump vigorously for a while longer, make sure there are no leaks. Now you are ready to start your engine. you will want to give it extra throttle. Once the engine starts decrease to throttle back to normal . Check for leaks while engine is running.....................CapG
jmurray97 likes this.
Capt. Gary Randall is offline
post #2 of 3 Old 07-07-2012
Senior Pirate
TropicCat's Avatar
Re: OOP'S I think I ran out of fuel !!!!
Where's the post you're responding to?
By the way, not all high-pressure pump's have a bleeder screw on the side of the pump. They have a bleeder on the low pressure side of the pump. Check any Yanmar. You bleed the hi pressure side at the injector and no one would ever recommend a newbie do this as the fuel under pressure could cause harm.
Tropic Cat
TropicCat is offline
post #3 of 3 Old 07-07-2012 Thread Starter
TropicCat, I'm not responding to a post that was already started. This was my first new Post
City marina to build self-service fuel station after three years without fuel - Corpu NewsReader News Feeds 0 07-16-2011 11:40 PM
Old fuel dennismenace111 Gear & Maintenance 24 08-25-2008 06:41 PM
What to do with old fuel? Classic30 Gear & Maintenance 27 09-04-2007 07:54 PM
Re: Diesel fuel- where to buy? NewsReader Mass Bay Sailors 0 07-06-2007 01:15 PM
Fuel sneuman Provisioning 6 03-26-2004 02:17 PM
