Edel 665 ...crack in deck / ceiling - SailNet Community
 1Likes
  • 1 Post By TQA
post #1 of 10 Old 07-07-2012 Thread Starter
I looked at an Edel 665 today. Pretty dirty and neglected from sitting on the cradle since fall 2010 in Toronto heat and winter cold. Sheets and halyards are all toast but I am getting such a great deal that I do not want to pass on it however there is this one crack inside on the roof that I need advice on how to fix.
It seems to be just around where the teak hand rail is attached on the deck.
All suggestions will be most appreciated....beer if you are in Toronto.
i_amcdn is offline
post #2 of 10 Old 07-08-2012 Thread Starter
Re: Edel 665 ...crack in deck / ceiling
I was thinking that I could add a handrail glued to the ceiling, as a re-inforcement. after the glass repair.
i_amcdn is offline
post #3 of 10 Old 07-08-2012
TQA
Bombay Explorer 44
TQA's Avatar
Whoa there. If those nuts are the ones holding that shrould mount and it looks as if they are, then you have a boat with a SERIOUS structural failure.
As well as fixing the visible evidence and that will need more than a bit of filler plus a glued on handrail, you need to investigate the other side as well.
Also from Sailingdog
It has a partially cored hull IIRC, and you need to make sure that water hasn't gotten in and caused any delamination. I don't believe the core in the hull will rot as I believe it is PVC-based foam.
The cross beams that connect the hulls to the bridgedeck are aluminum.
Corrosion is going to be a problem at the fasteners, since I believe the fasteners are stainless steel. I personally prefer cats that have the hull molded as a single piece... but that's just me.
The forestay connects to crossbeam that is also supported by a "dolphin striker" and that needs to be in good shape, otherwise the forestay support can fail.
Rudder shafts on this boat were aluminum originally. I believe the bearings were bronze... this is a galvanic corrosion problem in many cases, and should be checked closely.
I believe the deck is also cored, and needs to be checked for any signs of water intrusion or delamination.
Also, I believe the cabin soles are fiberglass and plywood, so you may want to check the sole for any water intrusion that may have rotted the plywood. I don't believe the plywood was fully encapsulated in fiberglass on these boats.
paul323 likes this.
TQA is offline
post #4 of 10 Old 07-08-2012 Thread Starter
Thanks....The other side looks clean and solid. Sole is dry inside. I will wait to have someone more qualified look at it....my DIY may have just expanded to include some outsiders.
Cheers.
i_amcdn is offline
post #5 of 10 Old 07-08-2012
Senior Pirate
TropicCat's Avatar
Looks like SD was commenting on a multihull.
This is a 22' mono built in the '70s. I hope you were given the boat as you're about to spend a lot of money repairing her.
Tropic Cat
TropicCat is offline
post #6 of 10 Old 07-08-2012
TQA
Bombay Explorer 44
TQA's Avatar
My bad thought it was an Edel cat.
Still think that crack looks bad. But at 22 feet I would get someone on a mast head halyard and pull the thing well over to see what happens.
TQA is offline
post #7 of 10 Old 07-08-2012
Senior Pirate
TropicCat's Avatar
at the risk of thread drift, where might one find sailingdog these days?
Tropic Cat
post #8 of 10 Old 07-08-2012
Irwin 25
andrewalexander's Avatar
The good news is that the Edel 665 is a solid fiberglass deck so this should not be a deck coring issue. The chain plate for the upper and lower shrouds is a two plate affair that is thru bolted between the hull to an inner plate that is anchored to an inner hull molding just aft of your second picture. I would guess that water has migrated through this area and has frozen and split the upper ceiling area where the split is showing up. It will take some minor fiberglass work to repair but I would be surprised if the structure is seriously compromised.
It would still be a good idea to have someone with experience poke around in that split to see if the damage is just superficial to to the interior ceiling material. It would suggest the thru hole bedding in the boat needs to be addressed.
Good luck...@
andrewalexander is offline
post #9 of 10 Old 03-18-2013 Thread Starter
In the end it was simple to fix.
I cut through the 12 inch wide wood inlay and pried it down about 12" either side of the cut.
There were no water stains or mold or anything that would suggest water leaks.
I stuck my 6-10 caulking gun in as far as I could on wither side and jammed the inlay back into the recess in the fibreglass. Other than the cut I made there is no other evidence. I may glue some LED strip lighting over the cut.
i_amcdn is offline
post #10 of 10 Old 03-21-2013
norahs arc's Avatar
Just read the thread and see that you found what I was going to tell you. It's common for this wooden trim to lift or drop away apparently.I had the same thing happen on one I owned. That said you have a boat that will sail nicely. They are very stable and quick. The only thing I didn't care for was that my 6 ft 200 lb body didn't have much room to move arround inside or out. Even with the cramped size I still spent up to 3 weeks at a time sailing it because it was just so enjoyable. Have fun and play safe.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
Looking for info on EDEL 665 Reboot11133 Boat Review and Purchase Forum 26 02-27-2017 12:03 PM
Hello, New Edel 540 owner and Cruiser EdelbutnotIdle Introduce Yourself 3 04-06-2011 10:13 AM
repairing crack on deck eggman2001 Gear & Maintenance 9 09-30-2008 01:47 PM
Safety of Edel Cat 35 as a blue water cruiser? flyfisher General Discussion (sailing related) 22 01-22-2008 03:15 PM
Edel 35 sport / PHRF ????? mangomike General Discussion (sailing related) 0 12-18-2006 01:35 PM
