Custom cut round plastic window for forward hatch - Page 2 - SailNet Community
post #11 of 15 Old 07-19-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Custom cut round plastic window for forward hatch
I was thinking of a mechanical ring or stop of some sort. Is there nothing but adhesive holding in the glazing on this type hatch? Most hatch inserts are held in both sides with a retaining ring. The matching rabbets should be on the inside with an inside plate/stop over the plexiglass to hold it in. The rabbet on the glazing should be what brings it up to exterior surface height. Maybe that's what the OP is describing.
I just finished replacing a piece of broken glass in a small port. Used a leftover piece of 3/8" acrylic. It was easy to do the rabbeting with a table saw, setting the blade depth and fence to right depths and then running the glass upright along the fence, rotating it around.
smurphny is offline
post #12 of 15 Old 07-19-2012
Romario, it sounds like a simple piece of 1/4" plexiglass (acrylic) that has had a 1/8" bevel cut into the edge with a router. For a plexi shop this is a simply job. But a lot of plastics shops are used to indoor work done cheap, and the raw material is bought in 4x8 foot sheets, so if you want something they don't have, they cleverly try to charge you for the whole sheet and keep the rest. (Ouch.)
For hatches (and ignoring the question of using cast acrylic instead of "structured" aka sheet material) you will get better life by looking for an acrylic that is meant for use as outdoor glazing, that is UV-resistant and scratch-resistant. If you find a shop that doesn't get all upset when you ask about this, the odds are they have the right material and are a better place to work with.
I'd guess the price of the job would be $50-100 depending on local prices.
But the plastic you dropped overboard? Technically, that's a MARPOL violation and a serious fine for putting plastic in the water. If it was at the dock...Heck, you'll save at least $50 by getting a mask and diving down to look for it. :-)
hellosailor is offline
post #13 of 15 Old 07-19-2012
Barquito
Barquito's Avatar
Better yet, throw the GF overboard with a mask to find the thing.
Valiant 32
Barquito is offline
post #14 of 15 Old 07-23-2012 Thread Starter
The best quote I got so far is $90 with a week lead time. There were actually only 3 replies from the dozen or so places I sent a request to, from 200 to 90 dollars quotes.
I wish I could get it back, I saw it sinking while we were under sail, I even contemplated jumping in for a second, but it was too late, by the time I jumped we would be too far away and the lens was sinking too fast.
Romario is offline
post #15 of 15 Old 07-23-2012
Senior Moment Member
SloopJonB's Avatar
I think you're describing the system used on opening portlights, particularly those with glass rather than plastic lenses. Modern deck hatches have the lens simply bonded in place with a combination adhesive/sealant like Dow 795.
SloopJonB is offline
Plastic Hatch emiller775 Gear & Maintenance 8 02-03-2011 02:10 PM
Scratch remover for plastic window CISCOJOE Gear & Maintenance 1 01-16-2009 04:21 PM
B32 forward hatch needed ows1id Bristol 5 02-27-2008 08:18 PM
forward hatch leak joec43 Morgan 5 12-22-2006 05:31 PM
Forward Hatch Cover Sup Gear & Maintenance 2 10-04-2000 04:34 PM
