Calling all Electric drive sailboat owners - SailNet Community
 2Likes
  • 1 Post By Mark F
  • 1 Post By DamonVT
post #1 of 9 Old 07-09-2012 Thread Starter
davidpm's Avatar
I'm very interested in electric drive sailboat setups but have seen only one first hand.
If anyone has access to an electric powered sailboat I would very much appreciate an chance to see your installation.
And yes I do know about the distance limitations of today's battery technology.
I liked the way one guy expressed it. He said his whole battery bank was the about the same as 2/3 of a gallon of gas.
But for some reason it is very appealing to me and would like to see a couple of actual installations in person.
davidpm is offline
post #2 of 9 Old 07-11-2012
Re: Calling all Electric drive sailboat owners
Hi David,
If you are ever in the Santa Cruz CA area you are welcome to check out my installation.
Mark F is offline
post #3 of 9 Old 07-11-2012 Thread Starter
davidpm's Avatar
Originally Posted by Mark F View Post
Hi David,
Thanks Mark
I'll be keeping a list.
What boat and electric setup do you have?
davidpm is offline
post #4 of 9 Old 07-16-2012
Hi David,
I have a 1976 Ericson 27 with a SolidNav Explorer electric motor unit (company is out of business). You might try contacting Electric Yachts, QuieTorque Electrics | Electric Yacht ,for locations of installations in your area.
Mark F is offline
post #5 of 9 Old 07-16-2012 Thread Starter
davidpm's Avatar
How is it working for you?
What is your battery config, range?
What is your amp hour draw at whatever speeds you happen to know.
davidpm is offline
post #6 of 9 Old 07-22-2012
Hi David,
You might want to check out the Yahoo group http://groups.yahoo.com/group/electr...s/messages?o=1
To your questions;
It's working great and has been for over 4 years
I have two separate 48 volt banks for propulsion, 4 group 27's and 4 group 31's
Range - I've motored for 7 hours at 4 knots and used most of one bank
At 4 knots amp draw is 20 amps, at 6 knots amp draw is 110ish
davidpm likes this.
Mark F is offline
post #7 of 9 Old 07-22-2012 Thread Starter
davidpm's Avatar
Hi David,
To your questions;
Thanks
davidpm is offline
post #8 of 9 Old 07-24-2012
deckofficer's Avatar
Check out the articles and links here.
Add to them if you have some more links or other input.
Integration of systems
Bob
WL7GS Whiskey Lima 7 Gone Sailing
deckofficer is offline
post #9 of 9 Old 07-26-2012
I just finished installing a 5.5 kW system from Propulsion Marine in my 1976 Ranger 33 that I keep near Burlington, VT. At this stage it works well but I need to permanently mount the components and do some watts-to-knots testing. Instead, I've only used it for maneuvering around the mooring and because of its ability to spin very slowly and the big new prop, it is much better at that than the old A4 and small prop.
The batteries are four Trojan AGM group 24. They probably have only a few miles range, but as I said I haven't tested.
They are charged by two Sanyo 195 W PV panel on a bimini frame. These are excessive, but the price was right and I couldn't find smaller ones that could charge 48v without getting too low wattage.
There are lots of good reasons!
davidpm likes this.
DamonVT is offline
Calling all electic drive boats davidpm Gear & Maintenance 62 04-15-2012 03:25 PM
Electric Drive? Lazlow Living Aboard 17 08-02-2010 08:42 PM
Electric drive huguley3 Gear & Maintenance 25 09-04-2009 12:56 PM
Electric drive owners need some advice southernwind Cruising & Liveaboard Forum 12 02-18-2009 11:32 PM
Would you buy an IP with electric drive? Architeuthis Island Packet 4 04-30-2008 04:38 PM
