Tohatsu 6hp Sail-Pro Version - Page 3 - SailNet Community
post #21 of 23 Old 08-16-2012
Re: Tohatsu 6hp Sail-Pro Version
I've had the Nissan Sail Pro on my Nordica 20 for one season. I replaced an 8hp Nissan four-stroke that was just heavy enough that I couldn't pull my motor bracket to up to the first notch, necessary to tilt the engine out of the water. I miss the electric start and the smoothness of the 2 cylinders--this is a rackety little devil-but the lighter weight and longer shaft are reasonable tradeoffs. If I had to motor an hour before hoisting the sails, the noise would be objectionable.
Having read the complaints from some people that the motor vibrates itself out of a straight position, I bought a bracket made by Tohatsu to lock the motor in position, then realized I can't use it because my motor mount is on the angled transom. In any case, it's useful being able to turn the motor when docking, and since I can reach the tiller it's not much of an issue if it moves slightly out of alignment.
cstpt is offline
post #22 of 23 Old 09-01-2012
fryewe's Avatar
Used my Tohatsu Sailpro to push the Dovekie on the Mohawk/Erie Canal for a couple of days this week both up and downstream through a few locks. Filled the three gallon tank before I left and refilled when I got back. One gallon for 25 statute miles with the throttle 50 to 75 percent when outside the locks and idling in neutral when in the locks. Boat at hull speed of 6 knots when at 3/4 throttle.
fryewe is offline
post #23 of 23 Old 09-01-2012
We have the regular 6HP 4 stroke on a fishing boat. Initially it was hard to start but after gapping the plug to proper specs it now starts easily and runs perfectly. Three hours of trolling and running in and out uses not quite a pint of fuel.
Paul T
dabnis is offline
So which version of this forecast do I believe? ilikerust General Discussion (sailing related) 4 10-08-2010 11:21 AM
Do you own a cruising version J Boat < 40' in SF area? SPC Boat Review and Purchase Forum 3 09-04-2010 04:38 PM
Jeanneau 50 DS Performance version SandySpit Boat Review and Purchase Forum 8 03-04-2010 11:31 AM
A European version of GPS will go ahead now ... IrishMistRacing General Discussion (sailing related) 19 12-03-2007 04:32 PM
Google Earth - New Version canadianseamonkey General Discussion (sailing related) 12 10-05-2007 04:32 PM
