Is there such a thing as a 3/4" NPT to 5/8" barb? - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 6 Old 07-11-2012 Thread Starter
smp
C&C 32
smp's Avatar
Send a message via MSN to smp
Mind the typo in the thread title .. mod please edit. Should read: 1/2" to 5/8"
My thru-hull is 1/2" and the groco strainer is 5/8". There was some heater hose on there before and that stuff is flexible so it all fit just fine ... I tried replacing that hose yesterday and learned of the difference. The hose I am replacing it with is the USCG certified stuff, 1/2" and it's STIFF .. so it won't go around the 5/8" hose fitting on the groco strainer. Both the 5/8" fitting and the 1/2" hose barb on the thru-hull are removable/changeable but I can't find any 1/2" to 5/8" or the other way around adapters. Does such a thing exist?
Thanks
edit: hmm .. is this what I'm looking for?
smp is offline
post #2 of 6 Old 07-11-2012
JimsCAL's Avatar
Re: Is there such a thing as a 3/4" NPT to 5/8" barb?
There's this. Conbraco Pipe To Hose Adapter
Does say both 1/2 and 5/8 hose so may still be a tight fit. Putting the hose end in very hot water before trying to slip it on will help.
JimsCAL is offline
post #3 of 6 Old 07-11-2012
Maine Sail's Avatar
Thanks
If this is for an engine you may strongly want to consider up-sizing the thru-hull and seacock to at least 3/4". 1/2" is often far to restrictive for an engine intake, if this is what it is for. Those adapters are made but be sure you get bronze if this is below water.
olson34 likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 6 Old 07-11-2012 Thread Starter
smp
C&C 32
smp's Avatar
Hi, yes it's for an Atomic 4. The original thru-hull and lines are all 5/8" :/
I wrongly thought the thru-hull was 1/2" when I replaced it, pretty stupid. Everything is bronze and I plan to stick to that. Engine temp is fine .. not sure if there is a big difference in 1/2" vs 5/8" for water volume .. my thinking is that there are likely greater restrictions in the water jackets, pump etc than in the thru-hull itself.
smp is offline
post #5 of 6 Old 07-11-2012 Thread Starter
smp
C&C 32
smp's Avatar
Wait a minute!
Really did not have enough coffee this morning .. the thru hull is 3/4"! Not 1/2". Jeez, my mind really only starts working properly after noon.
So if it's 3/4" and my hose is 3/4" and the hose is having a really hard time fitting onto the groco strainer .. what size is it? I am certain that it's not 1". Might be worth mentioning that I had to cut the old heater hose off of the strainer fitting. Didn't have any trouble getting it off the old thru-hull.
smp is offline
post #6 of 6 Old 07-31-2012
Brewgyver's Avatar
Did you find the answer, figure it out? If not, have you gone to Groco's web page:
GROCO MARINE PRODUCTS
If it's a 3/4" strainer, it'll have 750 in the model number, and the barb is for 3/4" ID hose.
Brewgyver is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
Is there such a thing as "Sailing OCD" (obsessive comp. disorder)?? NewsReader Mass Bay Sailors 0 06-28-2007 02:15 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
