Drilling A 5/8" Hole In The Hull? - Page 3 - SailNet Community
 4Likes
post #21 of 22 Old 07-14-2012
Re: Drilling A 5/8" Hole In The Hull?
Use a spade bit. You only need one hole, they are cheap. They don't self feed like a twist drill, so it won't tear a big ugly hole. The point comes through well ahead of the cutting edge, so you can finish from the other side if you want and get an absolutely clean hole.
If you HAVE to use a twist drill. Do NOT drill a smaller pilot hole, that will guarantee a rip out when it grabs. Remove the rake from the drill bit, using a diamond file or stone. Hold the bit horizontal with your right hand and the point away from you. Rotate until the cutting edge on the left is also horizontal. Hold the stone or diamond file horizontal and stroke it towards you on the cutting edge until you create a small flat. Rotate the bit to the other edge and repeat. Now you have drill bit that works excellent in all plastics, copper, and soft aluminum.
Gary H. Lucas
GaryHLucas is offline
post #22 of 22 Old 07-14-2012
just drilled
Just drilled a 1/2in hole through my side hull .
, used tape and a 1/2in hole saw and took it easy when just about through , no chipping or flaking in or out
Lost Parents is offline
Drilling Hole in Fiberglass Hull sailak Gear & Maintenance 16 03-17-2011 10:37 AM
Filling 3/8" hole in hull. Boat in the water. QueenElvis Gear & Maintenance 23 06-25-2009 09:55 AM
Cutting and drilling Acrylic 1/4" sheet for windows. zz4gta Gear & Maintenance 30 04-23-2009 12:06 PM
The boat seems to be leaking water through the "tiller hole"... martsmth Gear & Maintenance 2 05-26-2008 11:16 PM
Drilling A Drainage Hole in Sunfish Hull??? Gabbyfire Gear & Maintenance 4 06-06-2007 02:07 AM
