Drilling A 5/8" Hole In The Hull? - SailNet Community
 4Likes
post #1 of 22 Old 07-12-2012 Thread Starter
Question Drilling A 5/8" Hole In The Hull?
I'm going to be installing a Blue Sea CableClam 1001 in Abracadabra's stern this weekend. The model 1001 has a 0.63" (16mm) opening, which is approximately 5/8". That's smaller than my smallest hole saw, but way too big for a twist bit. What do y'all suggest? I was wondering if a Forstner bit would work well on fiberglass?
Thanks,
Jim
SEMIJim is offline
post #2 of 22 Old 07-13-2012
overbored's Avatar
Re: Drilling A 5/8" Hole In The Hull?
buy a hole saw the forstner bit might get ugly
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 22 Old 07-13-2012
you could probably get away with a spade bit, but same caveat as above. do you really want to risk a $200 repair because you saved $10 on a hole saw?
AncientTech likes this.
xymotic is offline
post #4 of 22 Old 07-13-2012
Senior Cruiser
sea_hunter's Avatar
Hole saw. Epoxy inside of hole then redrill to final size.
sea_hunter is offline
post #5 of 22 Old 07-13-2012
+1
Drill 3/4 ", fill hole with epoxy, then redrill 5/8".
Silvio likes this.
LinekinBayCD is offline
post #6 of 22 Old 07-13-2012 Thread Starter
Do they make holes saws that small? I assumed that, since I have two sets, and neither has a hole saw that small, that they didn't. But I'll stop by the local big box stores tonight, on the way home, and check.
As for the epoxy-filling: Not necessary. Abracadabra's hull is not cored.
*Hmph*... spade bit... Could work... if I was careful.
Obviously this is going to require more thought and research.
Thanks for the follow-ups!
Jim
SEMIJim is offline
post #7 of 22 Old 07-13-2012
If you use a spade bit, only use a new one for a sharper outer edge, light pressure and don't go all the way, then finish from the other side.
Wear a face mask to protect from fiberglass dust.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #8 of 22 Old 07-13-2012
Scurvy Dog
Reef33's Avatar
I don't understand why you can't just use a 5/8" twist bit such as this one (scroll down and select "5/8"):
DEWALT Metal | Find Tools and Accessories
Forstner bits are for drilling flat bottom holes and auger bits are much less stable than a standard twist bit. Spade bit would work, but again, harder to control than a standard twist bit. I agree with drilling part way then finishing from the other side for a neat edge. And I can't see drilling the wrong size hole and then repairing it to get the right size hole when you can just drill the right size hole to start with? But, I'm not an expert in drilling holes in boats, just wood.
Skipper Jer likes this.
Scourge of the Upper Chesapeake since 1993.
Reef33 is offline
post #9 of 22 Old 07-13-2012
Skipper Jer's Avatar
Whats wrong with a twist bit? Pretty sure one can purchase a 5/8 bit that has a shank turned down to 3/8.
Reef33 likes this.
Skipper Jer is offline
post #10 of 22 Old 07-13-2012 Thread Starter
Originally Posted by Reef33 View Post
I don't understand why you can't just use a 5/8" twist bit ...
I'm concerned about tear-out on the inside, and I don't believe I can get a drill in there to relieve the inside outer edge, first.
These things I know. But, sometimes, tools can be used in ways other than that for which they were intended.
I'm not an expert in drilling holes in either, but I do know this: Fibreglass is "chippy," or "flaky." For anything other than very small holes, it can be difficult to drill cleanly.
Jim
SEMIJim is offline
Drilling Hole in Fiberglass Hull sailak Gear & Maintenance 16 03-17-2011 10:37 AM
Filling 3/8" hole in hull. Boat in the water. QueenElvis Gear & Maintenance 23 06-25-2009 09:55 AM
Cutting and drilling Acrylic 1/4" sheet for windows. zz4gta Gear & Maintenance 30 04-23-2009 12:06 PM
The boat seems to be leaking water through the "tiller hole"... martsmth Gear & Maintenance 2 05-26-2008 11:16 PM
Drilling A Drainage Hole in Sunfish Hull??? Gabbyfire Gear & Maintenance 4 06-06-2007 02:07 AM
