Fresh water pump occasionally pulses - SailNet Community
post #1 of 8 Old 07-13-2012 Thread Starter
Udi
Hi,
I have a new fresh water pump, Flowpump fl-35. After a few weeks of using it, it started to pulse every 2-3 minutes even though all faucets are closed and there is no water leek. (to make sure of this i connected a short hose to the pump's outlet and blocked it. The pump still pulses every few minutes)
I am on a cruise now and cannot return to the shop i baught it at for the guarentee. Any ideas how to FIX the problem?
Thanks
Udi is offline
post #2 of 8 Old 07-13-2012
Bluenoser
jimjazzdad's Avatar
Re: Fresh water pump occasionally pulses
There is a little internal pressure regulating valve inside the pump (usually a rubber disc backed up by a spring...) That is probably the culprit. A bit of grit from the tank may have got lodged in the valve, allowing a tiny amount of flow to recycle around the pump diaphragm and causing the pump to lose pressure and cycle. Sorry, I can't recommend a fix, other than taking the pump apart for cleaning - something you probably don't want to do if its under warranty. BTW, an inlet strainer or filiter is a good idea on any pump of this type and may prevent this sort of trouble in the future.
jimjazzdad is offline
post #3 of 8 Old 07-13-2012
Senior Cruiser
sea_hunter's Avatar
It may be a small leak in the system. Shut the pump off overnight (not opening any taps etc) then turn it on in the morning; if it cycles you have your answer.
sea_hunter is offline
post #4 of 8 Old 07-15-2012 Thread Starter
Udi
Thanks for both replies!
jimjazzdad - your reply seems to have somehow solved the problem: i placed a strainer right before the pump, and the pulses stopped. I hope it stays like this.
Thanks again,
Udi
Udi is offline
post #5 of 8 Old 07-15-2012
BJV
Do you have an accumulater down stream from the pump? Even a small one can make a big difference.
bvander66 is offline
post #6 of 8 Old 07-15-2012
Had this happen once and the pump turned out to have a torn diaphragm.
Jeanneau 54DS
Minnewaska is offline
post #7 of 8 Old 07-15-2012 Thread Starter
Udi
What do you mean by "accumulator?
Udi is offline
post #8 of 8 Old 07-15-2012
Small tank that accumulates pressurized water. They keep the pump from cycling too much or be shocked by quick on and off of the faucet. The folks that make the fresh water pumps all make them as well, I believe. Not expensive.
Jeanneau 54DS
Tags
pressure pulses , water pump
Fresh Water pump for Universal M-12 jackytdunaway Diesel 10 05-24-2011 01:25 PM
Replace fresh water pump? SteveInMD Diesel 2 04-22-2010 08:54 PM
Fresh-water pump issues PolarisOne Electrical Systems 4 08-21-2009 02:14 PM
Fresh water pump question poopdeckpappy Gear & Maintenance 21 01-31-2008 05:59 PM
Fresh water pump for Jeanneau SO 372 russort Gear & Maintenance 0 07-25-2007 12:12 AM
