Transom thickness? - SailNet Community
post #1 of 4 Old 07-13-2012 Thread Starter
Question Transom thickness?
Anyone know the thickness of the transom on a Tartan 37? Getting ready to install a wind generator and want to make sure my screws are the right size before starting the work. Any help is appreciated!
didash is offline
post #2 of 4 Old 07-13-2012
kd3pc's Avatar
Re: Transom thickness?
you will likely want to use stainless bolts (several) that will go all the way through the transom glass, mounting pads as well as backing plates on each side.......simply running screws in to the glass is not going to work...
kd3pc is offline
post #3 of 4 Old 07-16-2012
Barquito
Barquito's Avatar
Just get some long bolts, and backing pad. Install, then cut the bolts off. Dress up the end with a file, or put a crown nut on the tip.
Valiant 32
Barquito is offline
post #4 of 4 Old 07-16-2012
Tim R.'s Avatar
Also, check here: http://www.tartan37.com/
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
lexan thickness deniseO30 Gear & Maintenance 36 03-29-2009 12:32 PM
Lexan thickness for deck hatch Alden68 Gear & Maintenance 38 03-13-2008 06:05 PM
portlight bulkhead thickness... Rockter Gear & Maintenance 7 08-26-2007 09:24 PM
fiberglass thickness SeanC. Gear & Maintenance 1 01-29-2006 12:29 AM
Teak Deck Thickness Mithril Gear & Maintenance 2 11-09-2005 04:17 PM
