Bilge pump question - SailNet Community
post #1 of 3 Old 07-13-2012 Thread Starter
Sn0wman's Avatar
Bilge pump question
We've finally moved up to a larger and slightly more complex boat, so expect to start seeing many more questions about things as I learn/dig into the boat.
My question is; this boat has a manual bellows type bilge pump located in the cockpit, (the kind where you open the access port, stick a handle in and pump.) with the intake hose located in the lowest part of the bilge. And where this seems to get funky is that it seems that the PO plugged a tsunami 1200 into the intake end of it. When I run the electric pump, the manual pump seems to act like its on the down stroke and pop the access port open. And when I pump the handle with out help of the electric, It really looks like the water is being sucked into the bottom of the tsunami electric pump.
To me this doesn't seem like a very efficient way to work, for either system. I haven't been able to completely trace all the hoses all the way back yet, and will do so to confirm my suspicion but, going on the assumption I am correct. I'm not wrong in thinking this isn't an acceptable set up?
Thanks for any input.
Sn0wman is offline
post #2 of 3 Old 07-13-2012
Re: Bilge pump question
What you are describing is a pretty common, but obviously wrong installation. One of the pumps needs to be moved to a seperate line.
Greg
Stumble is offline
post #3 of 3 Old 07-13-2012 Thread Starter
Sn0wman's Avatar
Greg,
Thanks for the input, well if its common that's better than just being completely screwed up.
It did seem to work for both pumps, but I know my little 500gph whale just about shot water out of my smaller boat, of course this larger boat has larger hose and a longer run but I did expect a bit more flow out of a 1200gph, and assumed having it pump through a gusher pump was slowing it all down.
Extra hose, and a separate run is on the to do list.
Sn0wman is offline
Bilge pump question cb32863 Gear & Maintenance 10 03-30-2012 10:50 AM
Bilge pump question jtober P30 9 12-22-2010 10:17 PM
Bilge pump question jtober P30 0 12-20-2010 02:49 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 12:36 PM
Bilge pump question bottleinamessage Jeanneau 8 08-23-2007 11:53 AM
