Silva Nexus Multi instrument setting - SailNet Community
post #1 of 3 Old 07-14-2012 Thread Starter
Our yacht has Silva Nexus Classic instrumentation with three multi instruments and a dedicated wind instrument.
The Multi instruments can be set to Speed, Depth, Navigate, or Wind readings... and two of them (Speed and Navigate) stay at those settings on power-up, but the third we use for Depth always reverts to Speed on start-up. Since the others have somehow stayed at there preferred settings, there must be a way to set an instrument to a preferred default ... but the manual loses a bit in translation, and I can't find the answer... can anyone help before I go nuts?
phil_s is offline
post #2 of 3 Old 07-14-2012
Geoff54's Avatar
Re: Silva Nexus Multi instrument setting
Have you tried to re-initialize the "rogue" instrument?
Each instrument is given a unique number. Problems can occur if two instruments have been allocated the same number. Your manual should give instructions on how to re-initialize the instrument but if you can't find those instructions, re-post and I'll see if I can find the documentation.
Geoff54 is offline
post #3 of 3 Old 07-15-2012 Thread Starter
Many thanks for your quick reply. I won't be back on the boat until next week, and will try your suggestion. The instrument works fine, and I can set it to the function I want, but it always reverts to Speed at the next start-up. I was wondering if a re-initialize would help... but was a bit wary of trying it in case I stuffed something else up. Will let you know.
phil_s is offline
Nexus instrument wired remote broke extremo Gear & Maintenance 1 01-31-2012 11:55 AM
Nexus wind instrument transponder rikhall Gear & Maintenance 0 01-15-2009 06:53 PM
Silva support @ $$$ The Daily Sail $$$ NewsReader News Feeds 0 04-20-2006 08:18 AM
HOREAU Appointed CEO Of Multi Cup SAS - Multi Cup 2006 @ ISAF - Sailing.org NewsReader News Feeds 0 04-08-2006 04:15 PM
Curious Customs: Setting Price Before Setting Sail? Dav-O Boat Review and Purchase Forum 9 03-23-2002 08:01 AM
