Using portable battery packs as AC source - SailNet Community
post #1 of 6 Old 07-15-2012 Thread Starter
The EDEL 665 I am refurbing over the next 4 months does not have shore power built in. As I work on it in blistering 35C+ humid weather this July I am thinking about what it will be like to sleep on it next summer and the need for some air moving fans.
There is the 12v battery for running lights and the one interior ceiling light that I will replace with LED's. There currently is no re-charging system (eg solar) and I am not sure how the previous owner kept it topped up. I think he only day sailed and never over nighted because the settee and berth cushions are nowhere to be seen. Cabin lighting and fans were therefore never an issue for him.
Our planned use will include many nights of "camping on water" therefore our needs dictate fans and more lights.
I plan on adding more LED lights in the cabin that would be AC.
I could get the 30A shore power cord and a 15A pigtail adapter and then run extension cords inside the cabin but we may not always be anchored / docked near shore power. Consequently I was thinking of one of these portable battery backs instead:
Motomaster Nautilus Battery Pack, 800 A | Canadian Tire
I could plug in AC fans and LED lights and recharge when ashore.
There is a nice cubby hole on the starboard side against the cockpit that could hold this
Comments?
Cheers.
i_amcdn is offline
post #2 of 6 Old 07-15-2012
Re: Using portable battery packs as AC source
Thete are some DC fans for marine use which draw little power.
They should work fine for you.
Outboard ?
WDS123 is offline
post #3 of 6 Old 07-15-2012 Thread Starter
Originally Posted by WDS123 View Post
Outboard ?
Yamaha 8 HP
i_amcdn is offline
post #4 of 6 Old 07-15-2012
My personal preference would be mounted DC fans. I like these and think they pull something like a half amp per hour:
Turbo 2-Speed Fan
Maybe upgrade the house battery and get a portable charger? Size the battery to have more than twice the amp hrs as the maximum draw these fans, lights, etc would have over the period you feel you would be away from the dock. Don't over discharge. I bet it isn't much and you could easily have a safety margin. You would have to be present for recharging with a portable unit, however. Installing a shorepower system is probably overkill, but would be excellent. If I was planning to use the boat alot and in need of the power, I would be tempted.
Jeanneau 54DS
Minnewaska is offline
post #5 of 6 Old 07-15-2012
JimsCAL's Avatar
Why 120VAC lights when there are lots of 12VDC units available. Just go all DC and install a charger. Will cover both when you have shore power available and when you don't.
JimsCAL is offline
post #6 of 6 Old 07-15-2012
I would only use 120VAC if I had an onboard generator. Or never left the dock.
Some things like an A/C unit have to be plugged in. Everything else 12DC works the best. Get a solar panel, and a couple of large house batteries. You'll be fine.
If you go down the road to an inverter be prepaired to spend a few of boat bucks to get everything working.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
So who packs a weapon on board? docrn Cruising & Liveaboard Forum 647 06-29-2011 10:53 PM
Using a portable battery charger onboard AdamLein Gear & Maintenance 19 01-13-2009 11:00 AM
Mack Packs dave6330 Gear & Maintenance 14 07-11-2008 12:36 AM
Community packs a punch (The Star) NewsReader News Feeds 0 10-10-2006 07:15 PM
Dehydrated Food Packs Low Salt bgitt Provisioning 2 03-21-2005 07:13 PM
