Outboard Engine Starting Problem - SailNet Community
post #1 of 3 Old 07-16-2012 Thread Starter
I have a 1993 Honda 9.9 outboard with a weird problem. Normally it is stored tilted up on the boat. When I put it down at the dock it runs just fine and it will run you out in the bay. When we are sailing we tilt it back up to get the prop out of the water. At then end of the sail, when we put it back down and then it won't start. Any ideas?
wfish11 is offline
post #2 of 3 Old 07-16-2012
mikehoyt's Avatar
Re: Outboard Engine Starting Problem
Try this link to ask your question. Is iBoats forum. Specifically the Honda and Tohatsu forum. They can answer most outboard motor questions.
You may wish to be a bit more specific though ...
http://forums.iboats.com/forumdispla...=29&order=desc
Mike
Mike
mikehoyt is offline
post #3 of 3 Old 07-16-2012
If you haven't done so make sure you turn off the gas valve before tilting the motor up. It is possible that the float valve in the carburetor is not closing when tilted up, flooding the motor.
Paul T
dabnis is offline
Problem starting my engine eobpt Gear & Maintenance 3 06-08-2009 10:20 PM
Sporatic problem Starting engine LJD Gear & Maintenance 10 12-07-2008 07:14 PM
Engine starting problem MikeJenkins Atomic 4 8 08-16-2008 11:18 AM
Starting problem Universal M-12 rlevy Gear & Maintenance 6 05-01-2008 03:10 PM
Starting Problem gpd955 Atomic 4 2 06-09-2006 05:19 PM
