replacing an bilge pump - SailNet Community
post #1 of 6 Old 07-16-2012 Thread Starter
Hello
I recently replaced my manual bilge pump hose to get it working it had some holes. I also have anelectric one Rule 800 that is not working i am not enirely sure if is getting power and not workingnor whst switvhonmy pannel controls it. The way my luck is running nothing would suprise me would . My question how do icheck for poweer and how do i replace it if i have to mostly concerened about splicingthe wires
Jeremy
Pearsom 10m
jhgreen is offline
post #2 of 6 Old 07-16-2012
Re: replacing an bilge pump
you get a small meter or just one of testers that has a 12v light in it. Turn on all your switches, activate your float switch and you will know if you have power. If you have power, simple enough to swap out a new pump.
No power, you have to track down the problem. Most likely at the switch but you could have a broken wire.
Catalina 34
chuck53 is offline
post #3 of 6 Old 07-16-2012
You need to test for power as mentioned above. I believe that pump has an internal float switch, which is often the culprit and not repairable. If you replace, I recommend a pump with a separate float switch. You will replace the switch before the pump, typically.
If you are unfamiliar with electrical work, keep in mind that it is the number one cause of boat fires. Number one.
Jeanneau 54DS
Minnewaska is offline
post #4 of 6 Old 07-16-2012
Totally agree. Checking out whether or not you have power to the pump is not difficult, but if you don't know how to do it, then you don't know how to replace the pump. Not trying to give you a hard time on this, but get someone with some boating/electrical knowledge to do this for you.
Catalina 34
chuck53 is offline
post #5 of 6 Old 07-17-2012
Look over his/her shoulder. Consider it a learning opportunity.
Capt Len is offline
post #6 of 6 Old 07-17-2012 Thread Starter
Thank you
jhgreen is offline
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
34 bilge pump HankJordan Pacific Seacraft 6 06-19-2010 05:54 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Brand new bilge pump that doesn't pump.... ugh Lancer28 Gear & Maintenance 6 02-08-2008 08:26 PM
