Whisker pole stuck - SailNet Community
post #1 of 4 Old 07-16-2012 Thread Starter
Whisker pole stuck
I have a Forespar telescoping whisker pole that has three sections. One section is very difficult to open and close. I've tried cleaning and rinsing to no avail.
Is there a lubricant that works well for this application?
Does anyone know how to disassemble one?
Thanks!
Loki9 is offline
post #2 of 4 Old 07-16-2012
Aspiring to be a Mexican
sww914's Avatar
Re: Whisker pole stuck
I would use triflow because it dries and doesn't stay oily. Also, I would tap around the tight area with a rubber or plastic hammer very gently so as to not bend the metal. That should knock the dirt and corrosion loose.
sww914 is offline
post #3 of 4 Old 07-16-2012
Tartan 27' owner
CalebD's Avatar
I'm sure you have some Marvel Mystery Oil on board.
I'd try that before PB Blaster which apparently does not play nice with rubber fittings.
Everybody has one:
CalebD is offline
post #4 of 4 Old 07-16-2012
fryewe's Avatar
Liberally spray the pole with vinegar ensuring it gets into each slide. Wait a while then spray again. Keep doing this until it frees up. And it will. Don't hit it with a hammer!!!
fryewe is offline
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Whisker pole jakesokol General Discussion (sailing related) 9 06-28-2011 03:22 PM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
whisker pole ?????? mangomike General Discussion (sailing related) 4 10-01-2006 08:05 PM
