Is it to early in my refit to apply VC17 - SailNet Community
post #1 of 14 Old 07-16-2012 Thread Starter
Iím well into a refurbish of a 1982 Cal 2-25, full keel version. The boat sits in my driveway on its cradle which is sitting on a trailer, so far my neighbors have been fine with it.. till recently, when some new people moved in next door. They are complaining about the looks do to the VC17 needing a new coat.
Iíve been holding off on the bottom job as it will be another year and a half before the boat splashes again so my question is.. is it too early to apply a coat of VC17? Iíve scoured the Interlux site and data sheets but only find minimum wait times, nothing about max times. Will I just be wasting my time and money applying a coat now? Could it actually do some damage to the hull?
Catalina 25
tpothen is offline
post #2 of 14 Old 07-16-2012
Re: Is it to early in my refit to apply VC17
You won't do any damage to your boat, but I don't think the VC17 will retain its anti-foulant properties sitting on the hard for a long time. You'll have to look that up to be 100%.
Jeanneau 54DS
Minnewaska is offline
post #3 of 14 Old 07-16-2012
Tartan 27' owner
CalebD's Avatar
You plan on launching your boat in January of 2014? In Minnesota? Hmmm.
Some bottom paints, notably Ablative paints, do lose some of their effectiveness if used too far in advance to launching. I'm not sure about VC 17 which I believe is a hard paint rather than an ablative but I do know that VC 17 is expensive.
That said, what makes you think that putting a coat of bottom paint on it will pacify your new neighbors? I'd bet that they will love it when you put a tarp tent over the boat for the winter. Is there some way you can move your trailer so it is less visible to the new folks on the block?
Everybody has one:
CalebD is online now
post #4 of 14 Old 07-16-2012
I suspect this is the start of a long tale.
Your new neighbor may just being polite, while checking with the township or community association. Some townships specifically prohibit work on boats and RV's in driveways, I would not want a neighbor working on a boat next to me.
Be extra nice to your neighbor and get a new clean tarp to cover the boat when you are not working on it.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #5 of 14 Old 07-16-2012 Thread Starter
Ok so it will be a few months longer than a year and a half
To keep the city happy I have to keep it in the driveway, to keep the wife happy I have to leave access to the garage door, so that means the boat has to stay were it is. I'm not breaking any city ordinances and the boat was there when they first looked at the house so all and all there is not much they can say about it. The boat does go to a storage yard over the winter.
I have talked to them about it, shown pictures of what it will look like, and they were fine with that but I'm also not going to spend that kind of money on it if I'm just going to have to do it again before launching.
VC17 is a hard paint.
Catalina 25
tpothen is offline
post #6 of 14 Old 07-16-2012
Tartan 27' owner
CalebD's Avatar
I know that a Cal 2-25 is not an ice boat.
If it were me I'd lean more towards putting on the VC 17 closer to the minimum amount of time recommended on the can. Why waste the anti-fouling properties on the air around your boat?
One recommended practice is to put a different color as a base coat then you want to use (say a coat of red underneath a coat of blue). This way you'll notice where the outer coating has worn thin. I've done this but I will say that even without the different color underneath I can usually find the most worn spots pretty easily.
I'd say that your boat falls under the "pre-existing non-conforming" usage of your property. Hopefully your neighbors will understand.
Everybody has one:
post #7 of 14 Old 07-16-2012
I don't discuss my member
Fstbttms's Avatar
If you want the manufacturer's opinion, ask your question here:
Antifouling - Yachtpaintforum.com - Page 1
Fstbttms is online now
post #8 of 14 Old 07-16-2012
If you decide that you do want to pretty her bottom, strip it and apply an epoxy barrier/primer coat. Wait until launch to apply the anti-foulant just prior to launch and the epoxy will allow for better adhesion.
Jeanneau 54DS
post #9 of 14 Old 07-16-2012
tommays's Avatar
The neighbors who do not like it still WONT like it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #10 of 14 Old 07-17-2012
Plant bamboo between your house and the neighbors, they wont have to look at your boat and trimming it will give them something to do and a new thing to bitch about
garyguss is offline
vc17 saltwater Lendow Gear & Maintenance 2 04-13-2011 04:51 AM
VC17 in saltwater Minnewaska Gear & Maintenance 6 05-05-2010 09:08 PM
VC17 or micron petrus45 Gear & Maintenance 4 05-21-2008 11:50 PM
Another VC17 Question sailortjk1 Gear & Maintenance 4 03-27-2008 03:30 PM
vc17 apply ..when??? thorJ30 Gear & Maintenance 3 11-10-2004 07:53 PM
