Barrier Coating Bottom; How to work around stands? - Page 2 - SailNet Community
post #11 of 17 Old 07-19-2012
Maine Sail's Avatar
Re: Barrier Coating Bottom; How to work around stands?
Originally Posted by hriehl1 View Post
I have a 28-foot, 6800# sloop currently blocked on its lead keel and laterally supported by 2 pair of stands and one v-stand on the bow. These were set by the trucker who delivered the boat to my house for refit.
When I had the bottom soda-blasted, they removed and re-set one pair of stands in a slightly different position to expose where the pads had been originally for blasting. Then they removed and re-set the other pair of stands. Their comment was that basically the blocks are taking all the weight, the stands are just for balance and one pair is actually sufficient. And clearly, the boat did not topple over when one pair was loosened and moved.
Now I am applying barrier coat and bottom paint. When done with all exposed areas, I'll want to also move and re-set the two pair of stands to expose the portions covered by their pads now.
Can anyone provide or direct me to a lucid, trusted description of the techniques for setting sailboat stands and jockeying them to expose covered areas? Or should I really buy or borrow a third pair of stands to always keep 2 pair in tension?
Photo is part-way through a PoliGlow application but also shows stands as they are now.
Thanks Hank
You're going to need to get the rest of that bottom paint off before barrier coating, unless the did blue gel below water? I see white gel....
I move the stands after each coat, all of them but one at a time, and feather the edges for a smooth transition. You'll want at least three stands per side plus bow.. Van you move stands with just five? Sure but if your boat falls over....well.....that's a tough call to the insurer..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 17 Old 07-19-2012
HANUMAN
RobGallagher's Avatar
It's vitally (as in your life) important to keep the chain attached at all times.
Move the stands one at a time by:
Loosen the chain a couple of links, make sure to reattach it to the stand.
Unscrew the pad and be sure that the boat is staying upright. Unscrew it just enough to slide the stand over (with the chain attached).
Move the stand 12 inches or so to it's new position.
Re-tighten the pad.
Re-tighten the chain.
Continue these steps one pad at a time.
The chain will keep the stand in place if the boat does shift to one side. Without the chain, the stand can slide or tip.
That is why yards won't allow you to tie anything to the chain (like tarps). If the chain goes, so can the boat.
The weight is on the keel. If the stands/pads are starting to make an indent into the hull they are probably too tight or need to be under an interior bulkhead.
That's my story and I'm sticking too it!
RobGallagher is offline
post #13 of 17 Old 07-19-2012
Barquito
Barquito's Avatar
That said, there are enough negative opinions expressed here to give me pause. I would have expected this to be discussed in Chapman's, Casey or Calder but not that I've seen.
If there where instructions in a book, it would probably go like this:
"1. Hire yard to do the work"
"2. See step one."
I am as frugal DIY'er as they come. However, I would just have the yard move the stands. There are just some things about boat work that scare the cr@p out of me, and moving stands is one.
Valiant 32
Barquito is offline
post #14 of 17 Old 07-19-2012
tommays's Avatar
While every boat that gets moved around here on a split trailer spends some time on three stands
Its not something you would do on a windy day OR put yourself even remotely in the possible fall area let along do any work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #15 of 17 Old 07-19-2012 Thread Starter
I move the stands after each coat, all of them but one at a time, and feather the edges for a smooth transition. You'll want at least three stands per side plus bow.. Can you move stands with just five? Sure but if your boat falls over....well.....that's a tough call to the insurer..
That was an old photo (of a PoliGlow job) before hours spent sanding below the waterline down to all gelcoat. The bottom was well-prepped and I've applied 2 coats of barrier coat thus far.
My plan was to do the entire job, 4 coats of PettitProtect barrier coat and 2 coats of Pettit Hydrocoat bottom paint, without moving the stands at all. Then move the stands to expose the 4 untreated "squares" that would then receive the full sand, barrier-coat and bottom coat treatment... feathering in to the surrounding finished areas.
Another asked if I saw the soda blasters reposition the 2 pair of stands to expose all areas. Yes I did. I'm just wary of doing the same unless I hear strong consensus (which I do not) that it is safe for an amateur. They mess with boat stands every day, I do not.
I'll look to rent a couple for my needs.
hriehl1 is offline
post #16 of 17 Old 07-19-2012
fryewe's Avatar
I couldn't get a yard to loan or rent me a couple of stands but I was able to talk one into selling me a couple of old stands for 65 bucks each. I think insurance was the issue when trying to borrow or rent...
fryewe is offline
post #17 of 17 Old 07-20-2012
Scurvy Dog
Reef33's Avatar
F-ing blood sucking lawyers and sue-happy a-holes in this country ruin it for all of us.....
Scourge of the Upper Chesapeake since 1993.
Reef33 is offline
cost of barrier coating rmeador Gear & Maintenance 7 09-08-2010 03:55 PM
Tips for barrier coating with Interprotect? mrybas Gear & Maintenance 4 08-20-2010 10:45 AM
Yards or companies that do barrier coating in Annapolis area? brak Gear & Maintenance 35 04-01-2009 11:26 PM
Aquaply M bottom coating gimmellsmom Gear & Maintenance 0 10-24-2008 08:03 PM
Barrier Coating rudder Sixbrothers Gear & Maintenance 3 02-08-2008 12:30 PM
