BILGE PUMPS - SailNet Community
Blogs
Old 01-28-2004
drynoc is on a distinguished road
BILGE PUMPS
Sorry to go over some old ground, but I would be interested in hearing whether or not the various members have automatic bilge pumps in their boats. I have a Santana 35, 1980 model, that I just bought, and it has never had one. That seems to suggest that one is not necessary (the actual bilges are no deeper than your fist) but having an automatic bilge pump seems like good counsel. I have this recurring nightmare of walking down the pier with five friends in tow and being able to board the boat at the spreaders. What''s the general consensus?
Old 01-28-2004
Sailmc is on a distinguished road
BILGE PUMPS
You don''t need one until you NEED one.
Old 01-28-2004
hamiam is on a distinguished road
BILGE PUMPS
no question in my mind that i would have one. i guess its a little false security, however, as if you really sprung a leak its likely that the pump would not be able to keep up with it and/or the battery would wear out.
Old 01-29-2004
GordMay is on a distinguished road
BILGE PUMPS
If your bilge is too shallow to accommodate a conventional submersible impeller type (centrifugal) bilge pump, you can install a self-priming diaphragm pump. The diaphragm pump is conveniently mounted out of the bilge, with only the pick-up (inlet) hose & strainer in the bilge. Alternatively, you could install a manual pump in the cockpit (pick-up is also in the bilge).
Regards,
Gord
Old 01-29-2004
BILGE PUMPS
Thanks to those who responded.
I have a manual pump, and it seems to work well. I was concerned about an automatic pump for those times when the bilges might need dealing with while I''m away. The one point seems to be the operative one to me: a truly serious leak which might hazard the vessel while you''re away would outlast the battery anyway.
Old 01-30-2004
BILGE PUMPS
drynoc:
You''re right - most automatic bilge pumps are merely convenience items.
A Bilge Alarm (High Water), could, however, alert you or a neighbour (or dock hand) to rising water.
Regards,
Old 02-17-2004
gaurre3 is on a distinguished road
BILGE PUMPS
common guys, automatic bilge pumps (w/ float switch) are not a luxury. they are manditory. In an emergency you need an automatic bilge pump, so that you could work on fixing the leak (problem). and if you are away from the boat, it could deal with a slow leak for a while until you come back and could recognize the problem.
Old 02-17-2004
capttb is on a distinguished road
BILGE PUMPS
My 16'' runabout even has an auto bilge pump, they say there are 2 kinds of trailerboaters, those that have launched without the transom plug in and those that lie about it. From personal experience I can attest to being amazed at how well most pumps keep up with a large leak.
On my sailboat, pump is wired direct to batteries (so it is always live regardless of battery switch position) shorepower keeps battery charger on so 2 batteries + charger should keep pump running for considerable time. (theoretically,Forever if batt. charger exceeds draw from pump). Most sailboats also have manual back-up pumps today.
Bilge Pumps Dave A Gear & Maintenance 6 06-08-2005 10:11 AM
Bilge diaper bmcald Gear & Maintenance 0 04-20-2004 01:58 PM
Bilge pumps oz_hole Gear & Maintenance 1 06-06-2003 02:36 AM
Bilge Question r3333 Gear & Maintenance 0 11-08-2001 09:11 PM
Brass Galley Pumps patrickjkueny Gear & Maintenance 2 07-12-2001 06:04 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
