Roller Furler Repair - Page 2 - SailNet Community
post #11 of 13 Old 08-03-2012
Re: Roller Furler Repair
i had trouble with my harken. turns out 2 set screws on bottom unit had backed out and entire system had slipped down. 3$ fix and seems like harken is known for this happening. might want to check this out.
captkirb is offline
post #12 of 13 Old 08-03-2012
travlin-easy's Avatar
The cost of bearing replacement may be quite expensive, and that's if you can find replacement bearings. You may want to replace it with an Alado system, which I did several years ago. Very easy to furl and maintenance free. Go to Alado Nautica USA Reefing and Roller Furling Systems Home Page
Good Luck,
Gary
travlin-easy is online now
post #13 of 13 Old 08-05-2012
I built my entire furler for under $100, and it has no bearings to fail. I have been using this type since 1982, with no failures.
Brent Swain is offline
Tags
furler ball bearings
Help identify roller furler StormBay Gear & Maintenance 0 11-11-2011 07:52 PM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 10:28 PM
Older roller furler set-up help. talismansigns Gear & Maintenance 13 08-11-2008 11:16 PM
Anyone know how to set up this roller furler somers12 General Discussion (sailing related) 2 05-26-2008 03:52 PM
Roller Furler Lubrication? ereuter Gear & Maintenance 28 06-06-2007 12:18 PM
