Roller Furler Repair - SailNet Community
post #1 of 13 Old 07-19-2012 Thread Starter
Sailor
Gladrags1's Avatar
My Harkin Roller Furler has become exceedingly difficult to furl, particularly if there is any wind and pressure on it. We sometimes need to apply a winch to it. To make it easier to roll up, we've even reduced pressure on the halyard. I guess this means that my 25 year old furler has probably reached the end of its life and is on life support but I was wondering if we can give it new life and replace the ball bearings? We cannot afford a new furler at this point as we've had much too many projects of late but I also don't want to be throwing money away by doing a project that won't have any effect on my desired outcome. Anyone replace ball bearings on their furler and did it work to create an easier experience?
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #2 of 13 Old 07-19-2012
ASA and PSIA Instructor
Re: Roller Furler Repair
Originally Posted by Gladrags1 View Post
My Harkin Roller Furler has become exceedingly difficult to furl, particularly if there is any wind and pressure on it. We sometimes need to apply a winch to it. To make it easier to roll up, we've even reduced pressure on the halyard. ...
You dont want to use a winch on a furler, you may end up busting the system. If you have difficulty furling due to wind pressure, bear off and furl the jib when its sheltered behind the main.
You should not ease the halyard as that increases the chance of wrapping it when furling.
Most furlers require some annual servicing, what does your Harken need?
sailingfool is offline
post #3 of 13 Old 07-19-2012
marcusc130's Avatar
Make sure you're not wrapping the halyard. That can cause failure of the forestay.
marcusc130 is offline
post #4 of 13 Old 08-03-2012 Thread Starter
Sailor
Gladrags1's Avatar
Understood. We don't like using a winch and it is only under "desperation" that we do so, carefully looking aloft. We head up, into the wind, to reduce pressure but it doesn't seem to help completely. In fact, we have a tough time rolling it up under mild conditions. This worsened when the forestay was removed and reattached to replace the bowsprit. However, we just got new sails and this sail is a 110% Yankee when the old one was a 100% Yankee. That works against me as there would be more resistance. The forestay seems tighter now so that should have made it easier to furl the sail. Regarding maintenance; what maintenance is called for? As I understand it, these units are pretty self contained and need an occassional fresh water wash to get the salt out.
So... back to my original question; do you think replacing the bearings would solve my problems? Anyone experience what I am seeing?
Mandolin
Bayfield 36
post #5 of 13 Old 08-03-2012
safira's Avatar
Have had the same problems you have stated ... here is what I did to cure them .... first I took down the sail so that I can get to the top swivel ... when I disassembled it there was a large amount of salt crystals in it, which is common. I used boiling water to clean the salt out and disolve it, then lubed it up very good. BTW the bearing were ok when I disassembled it.
So far no problrms scince then. My system is a hood system and has been on the boat scince 1980 ... with just a little minor maintenance they can last a long time ... now every 6 months I drop the sail and do the boiling water and lube the top swivle just to be good to it ...
safira is offline
post #6 of 13 Old 08-03-2012
You need to find the manual for your particular Harken system, check what routine maintenance is called for, and then perform it.
My Furlex unit called for annual greasing of bearings in the drum and swivel, but other makes have their specific requirements.
post #7 of 13 Old 08-03-2012 Thread Starter
Sailor
Gladrags1's Avatar
Thanks for the comments. My furler is an older furler (1987?). Unfortunately, when buying the boat, I did not get a manual from the PO and am having some issues identifying the correct model from the Harken site on-line. I will look more closely at the furler to see if I can locate some more identifying info.
From the manuals I did read, they pretty much state that the bearings need a fresh water wash and spray with McLube. I was just doubtful that this would make a dramatic difference but it is worth a try before more invasive and expensive routes. Sounds like it provided a dramatic difference to Safira. Thanks again!
Mandolin
Bayfield 36
post #8 of 13 Old 08-03-2012
HANUMAN
RobGallagher's Avatar
Mclube is amazing stuff.
RobGallagher is offline
post #9 of 13 Old 08-03-2012
overbored's Avatar
if you replaced the forestay and know it is worse until you lossen the haylard and new sail then check that the upper swivel is not going to high and draging on something at the end of the travel. also the bearings are torlon balls and can be replaced if need be. try putting Mclube One Drop on the bearing balls. if it is an older one then it may have the old Delrin balls bearings and they should be replaced with torlon bearings. http://www.harken.com/pdf/4414.pdf near bottom of page is the bearing part numbers
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 13 Old 08-03-2012 Thread Starter
Sailor
Gladrags1's Avatar
Great help! I will look up to make sure that the swivel is not too high - somehow didn't consider that! To replace the bearings, do I need to disassemble the whole unit and remove from forestay (particularly getting to the swivel)?
Mandolin
Bayfield 36
Tags
furler ball bearings
Help identify roller furler StormBay Gear & Maintenance 0 11-11-2011 06:52 PM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 09:28 PM
Older roller furler set-up help. talismansigns Gear & Maintenance 13 08-11-2008 10:16 PM
Anyone know how to set up this roller furler somers12 General Discussion (sailing related) 2 05-26-2008 02:52 PM
Roller Furler Lubrication? ereuter Gear & Maintenance 28 06-06-2007 11:18 AM
