Non skid on companionway steps? - SailNet Community
post #1 of 15 Old 07-19-2012 Thread Starter
The nasty plastic non-skid that had been stuck to the companionway steps has started to come off, so I took it off completely.
Noticed that what Bristol seem to have done, is leave the leading edge of the steps in raw teak, unvarnished. The rest is varnished.
What's your preferred approach to making them non-slippery?
MarkSF is offline
post #2 of 15 Old 07-19-2012
JimsCAL's Avatar
Re: Non skid on companionway steps?
My boat came with varnished teak steps with grooves cut in. After my wife slipped on them and fell down into the cabin injuring her back, I put 3M non-slip tread on them. Two years and its holding up nicely. An replacing it when it starts to look shabby will be easy and inexpensive.
JimsCAL is offline
post #3 of 15 Old 07-19-2012
I use stick on non-skid material from the hardware store, cut to fit. Made to be used for homes outside steps.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #4 of 15 Old 07-19-2012 Thread Starter
JimsCAL,
Is that the adhesive tape you are referring to, or something else?
MarkSF is offline
post #5 of 15 Old 07-19-2012
JimsCAL's Avatar
Originally Posted by MarkSF View Post
JimsCAL,
Yes. But its a nice thick vinyl and surprising durable and easy to clean. I found the grey in a 3 inch width and it matches my interior colors very nicely.
JimsCAL is offline
post #6 of 15 Old 07-19-2012
Bristol 45.5 - AiniA
I used similar stick-on material (for bathtubs as I remember) that I cut in strips to fit between the grooves on the steps of my Bristol. After attaching I put a coat of varnish over everything so that they appear a light tan color and blend in well. Been working great for several years.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #7 of 15 Old 07-19-2012
A ladder mat can be made to fit the size of the tread. It can be made with any small material that you have. After it's glued or tacked on to the tread it's usually painted white.
Very salty.
knothead is offline
post #8 of 15 Old 07-19-2012
72 C&C Corvette
CorvetteGuy's Avatar
How bout some silica sand mixed with varnish good and grippy.
CorvetteGuy is offline
post #9 of 15 Old 07-23-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Rustoleum has a good nonslip additive in their marine line it mixes evenly and resists settling in the pot. Thinkitmight work very well with a satin urethane varnish...
oysterman23 is offline
post #10 of 15 Old 07-24-2012
jsaronson's Avatar
I use the 3M white non-stick sold on a roll at West. I found an equivalent in brown on-line.
jsaronson is offline
Help-switch and warning light under companionway steps on Beneteau 390 leonem Gear & Maintenance 7 10-10-2011 05:22 PM
baby steps MtHopeBay General Discussion (sailing related) 17 06-14-2009 09:09 PM
A boat with few companionway steps dwightgry Boat Review and Purchase Forum 10 05-13-2008 11:25 AM
mast steps egregerson General Discussion (sailing related) 1 08-21-2006 02:04 PM
Companionway Steps and Dogs sroth Living Aboard 4 07-23-2002 07:41 AM
