Single-handed Conversion - SailNet Community
 1Likes
  • 1 Post By Stumble
post #1 of 8 Old 07-23-2012 Thread Starter
Question Single-handed Conversion
I am toying with the idea of converting/modifying a boat so it can be more easily sailed single-handed. However, I have no idea of how to do that or what is involved.
Do you know of any people/companies/publications that have gear for that purpose and/or can help me figure out what modifications to make? (My kids tell me to just sell it and buy a single-handed boat.)
Thanks, Richard
rlltrash is offline
post #2 of 8 Old 07-23-2012
Re: Single-handed Conversion
What kind of boat is it? For one, I'd try to have the headsail on a furler, and have all lines (sheets, halyards, furling line, etc..) leading back to the cockpit, with a good number of winches around the cockpit.
jambone is offline
post #3 of 8 Old 07-23-2012
One of None
deniseO30's Avatar
Ditto on what JB asked. Single hand set up is one of the lower cost things one can to to their boat.
My last project!
deniseO30 is offline
post #4 of 8 Old 07-23-2012
tommays's Avatar
My Cal 29 does well with simple low cost things
1. I can trim the mainsail and reach the jib winches form the wheel
2. All the sail furling/reefing can be done while standing in the cockpit with no need to go forward unless something failed
3. Spending enough time to understand the amount of sail and trim to keep a balanced helm you do not have to fight with
I owned a J24 for a LONG TIME and know all about modern stuff and old stuff like the twin mainsheets allows a LOT of control WITHOUT a traveler to knock your knees on moving around the cockpit
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 8 Old 07-23-2012
jsaronson's Avatar
Lazy Jacks (if no main furler), Auto pilot and a spinnaker sock too.
jsaronson is offline
post #6 of 8 Old 07-23-2012
Junior member, rest old
msmith10's Avatar
The single best item for singlehanding is an autopilot. It lets you pay close attention to sail trim, go to the foredeck for extended periods, go below for a beverage, and gives you a break from steering which can be just plain tedious.
Learn to heave-to. It's free.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #7 of 8 Old 07-24-2012 Thread Starter
Thank you all for your comments. Sorry, I should have mentioned the boat - a 19' Lightning class dinghy. This is not a big boat, but it gets busy in a brisk wind. There is also a ballast problem with just one person aboard.
I know that there is single-handed gear for larger boats. How about for a dinghy?
Richard
rlltrash is offline
post #8 of 8 Old 07-24-2012
Richard,
It's possible, but it would likely cost more to do than it would cost to get a boat more usable from the get go.
First I would suggest looking at the Harken dinghy furler for the jib. They work great, and are stock on a lot of newer small boats (VX OD, Melgus 24, ect).
Lazy jacks for a 19' are a little much, but a multiple purchase sheet system would be a good idea.
My first thought would be to simplify, simplify, simplify. There are a lot of strings on a Lightning, many of which can be eliminated. All tweeky lines, like jib down haul, ect should be dumped.
You might want to look at a non class smaller jib. This would allow a self tending jib track, and eliminate a bunch of extra work. Take a look at the VX OD system. It works amazingly well, with just two lines. A traveler line (in and out) and the sheet, with an adjustable tack attachment that allows you to control leech tension.
For a Lightning in particular you really need a lot of ballast as I remember (haven't sailed one in a few years). Short of redesigning the boat massively I don't see anyway to add ballast.
msmith10 likes this.
Greg
Stumble is offline
Boat for Single-Handed JazzmanSailor Learning to Sail 29 07-01-2013 01:42 PM
How to Get into this... single handed? WhatTheFoley Seamanship & Navigation 24 08-14-2009 02:59 PM
Single handed with too much wind sailbot Learning to Sail 73 09-06-2008 11:43 AM
Single handed Jeffamc Cruising & Liveaboard Forum 24 03-13-2007 01:37 PM
Single-Handed Sailing John Kretschmer Her Sailnet Articles 0 10-19-1999 08:00 PM
