outboard in a chop - SailNet Community
post #1 of 11 Old 07-23-2012 Thread Starter
timangiel's Avatar
outboard in a chop
If you are running an outboard in a chop, and the prop starts coming out of the water for a few seconds at a time, is that harmful to the motor?
timangiel is offline
post #2 of 11 Old 07-23-2012
Lightbulb Re: outboard in a chop
Not once in a while, but Yes, if it happens very much.
And then there's the obvious problem of going slow with the motor not putting any thrust into the water.
If it's a common problem, you need a lower-mount bracket, or, far more likely, a longer shaft (25") outboard.
olson34 is offline
post #3 of 11 Old 07-23-2012
davidpm's Avatar
I had a Catalina 25 last year with a 9.9 merc outboard.
The prop was in the water just below the cavitation plate.
It popped out in rough water a lot just like you said.
I was told the cavitation plate should be several inches below the water.
davidpm is offline
post #4 of 11 Old 07-23-2012
Some of the newer motors have rev limiters. You might check with the manufacturer to see if yours has one? Tohatsu , maybe others, have a 25" shaft model. We have a 6HP, runs perfectly.
Tohatsu Outboard Motor 6hp 4-Stroke
Paul T
dabnis is offline
post #5 of 11 Old 07-23-2012
Once known as Hartley18
Classic30's Avatar
Dock
Even with a rev-limiter, you still really should throttle back each time the prop comes out of the water to avoid fatiguing (and eventually snapping) the shear-pin, which would be rather unfortunate if you were close to a lee shore at the time.
Having a long-shaft outboard would mean it should come out less.. but having the prop come out of the water each time you go over a big wave is just one of the disadvantages of using an outboard on the back of a yacht.
It's either something you learn to live with - or you get an inboard.
Classic30 is offline
post #6 of 11 Old 07-25-2012
Get your crew of sunbathers away from the bow and move them as far aft as possible/comfortable...that's about all you can do while it is happening.
'79 San Juan 7.7
Joe Pool Lake
DFW area TX
Sailing year 'round
(Not up North)
FlyNavy is offline
post #7 of 11 Old 07-25-2012
Courtney the Dancer
jrd22's Avatar
Over the long run it will probably shorten the life of the engine some, but if it's an intermittent thing it probably doesn't hurt it much as long as you're not at full throttle. When the prob comes out of the water the cooling water intake also comes out of the water and then the prop hits the water again at high rpm and puts the engine under a huge load right when there is no water. Over a prolonged time the engine probably runs hotter than normal. The prop is also prone to spinning in the hub when this happens too, which will leave you with very little propulsion if it gets bad enough.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #8 of 11 Old 07-25-2012
Overall, rev limiter or not, it is not a good thing. Besides sounding scary you are losing your thrust. I used to see this happen very often on San Francisco Bay. Not good if you are trying to beat off of a lee shore or other bad places. Suggest, that if possible, you lower your mount or as mentioned earlier, get a longer shaft motor.
Paul T
dabnis is offline
post #9 of 11 Old 07-25-2012
If you have sea room, you can alter course and motor downwind. The waves will then be overtaking the boat from astern, keeping the prop immersed as it slides down the face of one wave, as well as when it climbs the face of the wave ahead. You might not arrive at your destination at the time planned, but you might save damage to the engine. Cavitation happens mostly when motoring to windward, against the waves.
Sailormon6 is offline
post #10 of 11 Old 07-25-2012
Huck
smallboatlover's Avatar
ive found out that going side ways to the waves, Helps the motor always stay in the water in rough conditons bad to keep the boat like that when really rought but best way to go when just a small to medium chop.
16' mistral sailboat, And 27' coronado
smallboatlover is offline
Short chop hull form tpm1950 General Discussion (sailing related) 2 09-10-2011 10:11 AM
Overhangs in a Lake Erie Chop GaiaOrion General Discussion (sailing related) 1 09-05-2009 01:56 PM
Towing a dingy in chop sailr4 Seamanship & Navigation 7 12-29-2004 02:06 PM
Best Outboard windylake Learning to Sail 4 08-13-2003 09:07 AM
best boat design for nasty chop dan s Boat Review and Purchase Forum 1 07-18-2002 03:13 PM
