07-24-2012
Re: Raymarine ST4000 MkII lever issue
I had the same issue. Common wisdom is a new belt and adjustment. I did that with minor improvement. So then I started using a bungee to hold it engaged. It worked but it I wanted it fixed right.
I took it apart again and realized that there was too much friction in the "lever wheel". (the wheel that the lever pushes against the belt to engage). The friction was enough to kick it out of fully engaged.
I took it apart, cleaned it, "polished" it, and lubed it. It's been perfect ever since.
