-   -   Wi-Fi (http://www.sailnet.com/forums/gear-maintenance/90087-wi-fi.html)
Cruisingdad 07-24-2012 03:34 PM
Wi-Fi
Hey guys/gals,
I need to buy a Wi-Fi extender for the boat. I can mount it on my solar arch.
I don't really want to run it up th mast if I can help it. I also considered putting it on the end of a pole, much lik a SSB antenae or VHF Antenae that can be raised and lowered.
I have had the Bullet 2hp reccomended to me by a knowledgeable sailor with it. It is on the short list. Has anyone used 5 mile Wifi or one of the others mentiond in this PS article:
http://www.bitstorm.com/downloads/PS...Fi_Article.pdf
Thoughts? Need to get one quick or I will not be able to get on easily and we will have to make Smackdaddy a moderator. Place will go down hill quickly. Can you say Mayday??
J/K, but serious about getting one very soon. Thanks for the ideas.
Brian
SVAuspicious 07-24-2012 04:06 PM
Re: Wi-Fi
Any of the Ubiquiti Bullet solutions are excellent. You can do your own or buy a kit from islandtimepc.com or wififorboats.com or any number of other vendors.
My experience with the Alfa based solutions is not nearly so good, although I do carry an Alfa in my go bag on trips.
Cruisingdad 07-24-2012 04:08 PM
Re: Wi-Fi
What is an alfa based? What does that mean?
Brian
SVAuspicious 07-24-2012 04:36 PM
Re: Wi-Fi
Alfa: http://www.amazon.com/Alfa-Wireless-Original-Screw-On-9dBi/dp/B001O9X9EU
If you open up most (98% or more) marine wifi solutions you'll find a Bullet or an Alfa inside repackaged. The Wirie is an Alfa in a box. IslandTimePC.com and WiFiforBoats.com are Bullets.
My experience with Bullet-based solutions is much better than Alfa-based solutions. Once you chose between those two it comes down to customer service.
IslandTimePC has a great reputation among cruisers. I have met the owner and think well of his expertise based on our discussion. I haven't bought anything from him. I put my own system together. If I was starting over I'd probably just buy one from Bob.
sea_hunter 07-24-2012 04:54 PM
+1 Simple solution.
capttb 07-24-2012 04:55 PM
Re: Wi-Fi
I just installed a Wirie AP last week, mounted on the stern pulpit, this one has a hotspot built in so you just need a 12 volt connection, not USB, then you have your own wireless network on the boat.
I've only tried it in the marina but before I could only see 5 networks and none were strong enough to connect. Now there's hundreds but I just connected to the nearby Marina Inn.
Install was comparatively easy, just run the power cable thru transom and up to the panel with a 2 amp fuse.
You could put one together yourself no doubt, but when I started pricing out components it didn't seem too bad.
hellosailor 07-24-2012 05:22 PM
Re: Wi-Fi
Brian, depending on how technologically impaired you feel and how fat the budget is...
That Alfa sells for $35 on Amazon then all you need is a longer USB cord to get it out of the cabin. Yes, the USB cord length limits position but for $35 versus 250+, I'd try it first.
Which also means you'll need to use the Wifi tools that come with your computer, to choose and connect to a network. Which isn't such a big deal these days.
The many folks who repackage it...OK, they're entitled to a profit if they make life easier but really, how badly can you lose by trying the $35 solution first? And at that price, you can carry a spare and sell it to the next hapless cruiser. :-)
TQA 07-24-2012 05:34 PM
Re: Wi-Fi
Wirie $250
Alfa $25 + extension high gain aerial $10 stick the aerial out the hatch and bobs your wifi.
capttb 07-24-2012 07:05 PM
Re: Wi-Fi
So $35 for parts, a 15 foot USB cable and a roll of duct tape and you got WiFi for 1 laptop, tape it to your forehead and you can have WiFi all over the boat.
Just thought of a new product, mount the whole shebang in a straw hat with a solar panel and you are a mobile extended range hotspot.:)
remetau 07-24-2012 07:12 PM
Re: Wi-Fi
Brian,
I was using a Bullet on a omni antenna that I would haul up the backstay using a halyard. This uses power over ethernet so only one cat5 cable to run which I connected to a router for distribution in the boat.
