Hard bimini - SailNet Community
 5Likes
post #1 of 53 Old 07-24-2012 Thread Starter
patrscoe's Avatar
Hard bimini
I saw a sailboat with a hard bimini. Very interesting concept.
I did some research online and saw someone built one and used starboard as a top surface.
Not saying I'm going to build one but again, I like the concept.
Does anyone have a hard bimini and any opinions about them? Pros and cons.
Patrick
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #2 of 53 Old 07-24-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: Hard bimini
My dodger extension/bimini is some kind of vinyl where as the dodger roof is fibreglass.
I am currently looking for a fibreglass sheet supplier down island as I want to replace the vinyl with a hardtop.
TQA is online now
post #3 of 53 Old 07-24-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Hard bimini
You never fold the thing away ?
We have cockpit enclosure of canvas and clears with solar panels over. Theoretically one never needs to fold away the top but I always do when we sail as I like to be able to look up at the main. Even the solar panels block that to some extent and I'm thinking of moving them out the back onto an arch.
While I like the ability to enclose the cockpit there are just so many times when I want clear view up.
Andrew B
killarney_sailor likes this.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #4 of 53 Old 07-24-2012
travlin-easy's Avatar
Re: Hard bimini
A hard Bimini is essentially an inexpensive version of a Tee-Top. I thought seriously about custom making a Tee-Top for my Morgan 33 O.I., but it was cost prohibitive. I've had Tee-Tops on five powerboats and they are very sturdy, solid as a rock, have great electronics boxes suspended on the underside of the top and you don't have nearly the number of vertical supports to climb around in order to reach the foredeck. Most have optional side curtains and some have full enclosures available that allow you to sail comfortably in cold weather.
Cheers,
Gary
travlin-easy is online now
post #5 of 53 Old 07-25-2012
St Anna's Avatar
Re: Hard bimini
I had one made from a ss frame and fibreglass sheeting 2.5mm thick. The same stuff they use for refridgerated truck bodies.
I have clears back and sides and a polycarb 'windscreen' - works great. Can keep out of wind/sun/water etc or open it all up for air!
St Anna is offline
post #6 of 53 Old 07-25-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: Hard bimini
Andrew B
Never gets folded away. If it is remade as hard I guess I would have to leave it up even in a hurricane where as I could strip the current one off in 20 minutes.
The dodger front can be unzipped for extra ventilation when hot.
I am tall enough and the current size of the bimini is such that I can look over the top to check sail set. Short crew complain though!
TQA is online now
post #7 of 53 Old 07-25-2012
Senior Cruiser
sea_hunter's Avatar
Patrick
Our boat came with a soft bimini and soft dodger connected. As the canvas was over 6 years old in SoCal sunshine we looked to replace the material. After a number of quotes in the 6K range and wanting to install solar panels to the top we decided on building a one piece hard top to replace both the dodger and bimini. I built it with a foam core and 24.5oz roving-strand cloth with West epoxy and measures 10'w x 12'. I installed red-white lighting and a Lewmar Ocean hatch over the wheel similar to the existing ones elsewhere on DreamKetchr. It will have removable soft sides with eisenglass and screens. We're getting ready to mount it this month, and are looking forward to the idea that we'll not have to replace the soft top again as well as the add protection from weather.
sea_hunter is offline
post #8 of 53 Old 07-25-2012
Re: Hard bimini
Pictures?
peterchech is offline
post #9 of 53 Old 07-25-2012
Senior Cruiser
sea_hunter's Avatar
[quote=peterchech:901064]
Pictures?
Coming soon to a theater near you. It will be a progressive view from mockup to form to finishing to paint then on the boat. We're at the paint phase right now.
post #10 of 53 Old 07-25-2012
One of THOSE!
2Gringos's Avatar
Re: Hard bimini
For those in the planning stages, check this stuff out.
Solid cellular PVC Sheet | PVC Sheet Manufacturer | AZEK Sheet
PVC sheets, strong, maintenance free. Can bolt solar panels right to it, walk on it, etc.
Expat Life in the Devil's Triangle:
2Gringos is offline
Hard Bimini Construction LarryandSusanMacDonald Gear & Maintenance 10 09-21-2011 12:33 PM
hard bimini? rmeador Gear & Maintenance 12 03-10-2011 01:04 PM
To bimini or not to bimini that is the question davidpm General Discussion (sailing related) 16 09-14-2008 10:05 PM
Hard dodger and bimini S/V Perfect Partner General Discussion (sailing related) 2 05-14-2006 08:07 AM
Hard Bimini c172guy Cruising & Liveaboard Forum 5 10-07-2003 06:56 PM
