Flushing a saltwater outboard. How long and how often? - SailNet Community
 1Likes
post #1 of 11 Old 07-25-2012 Thread Starter
SPC
I can't use the hose attachment option to flush my Honda 5HP. Instead, I run the outboard in a bucket with fresh water being added as the fresh water in the large plastic container is circulated through the motor and gives me a shower -- boat on the trailer on the hard after sailing.
How long do I need to flush (running at near idle in neutral in a bucket) and do I need to do it every time that I sail?
Thanks
Melrna likes this.
SPC is offline
post #2 of 11 Old 07-25-2012
casey1999's Avatar
Re: Flushing a saltwater outboard. How long and how often?
I used to have a 35 hp Honda outboard. I used the "ear muff" type device you just stick on to cover the cooling water inlet of the engine. I would run the engine at idle or a little more for maybe 5 minutes to flush. Did this after every use.
The West Advisor: Outboard Motor Care
casey1999 is offline
post #3 of 11 Old 07-25-2012
Senior Cruiser
sea_hunter's Avatar
I flush every time I use it.
sea_hunter is offline
post #4 of 11 Old 07-25-2012
Once known as Hartley18
Classic30's Avatar
Dock
A good question.
Since it's not really a good idea to leave fuel to evaporate in the carburettor, my suggestion would be to start it up on idle in the bucket as you do now, then disconnect the fuel line and leave the motor to run itself out of juice. You'll find that's more than long enough to flush the engine out.
Unless you're out on a daily basis, yes, you really should flush it after every time you sail.
Classic30 is offline
post #5 of 11 Old 07-25-2012
casey1999's Avatar
Originally Posted by Hartley18 View Post
A good question.
That is a good idea. Now I remember I used to do that with my honda (been 10 years since I had the engine). With the alchol in the fuel now, good to have the carb dry of fuel. I never had a fuel problem.
post #6 of 11 Old 07-26-2012
My OB is on the dinghy and gets used about once per week. Sometimes more often. I must be a heretic, because I've never flushed an outboard during the season. It does get flushed at the beginning and end of every season, when I change the oil and run her up on the hard. (I rechange the oil that has been sitting all winter) Coincidentally, I pulled an internal zinc last year and could see inside the motor. There was very little scale and the zinc still looked brand new. Motor was 6 years old at that point and I would estimate had five hundred hours on her. 19.9hp Tohatsu
p.s. Never flushed a dozen other OBs I've had over a lifetime either.
Jeanneau 54DS
Minnewaska is offline
post #7 of 11 Old 07-26-2012
I have done it both ways. Had a 15HP two stroke on a Coronado 25 for many years, never flushed it, no problems. However, had a 35HP two stroke on my fishing boat that I flushed every time I used it in salt water. Had to replace the thermostat and was very surprised as to how much salt or other? debris was inside the water passages. Suggest you flush when you can, can't hurt anything assuming you are getting proper water flow. And yes, drain the carb or run the fuel out if you are not going to use it in a few weeks.
Paul T
dabnis is offline
post #8 of 11 Old 07-26-2012
tommays's Avatar
Most outboards live there whole life on a mooring and NEVER get flushed SO anything you do is GOOD
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 11 Old 07-26-2012
Classic30's Avatar
Dock
Tommays, just because the boat is on a mooring doesn't mean you can't flush the outboard at least once in a while. The bailing bucket filled with fresh water and shoved under the drive legs works just as well on smallish outboards as it does on land.
..but, you're right - many people simply don't bother and will get away with it for a few years anyway... before it becomes more useful up the other end - as an anchor.
Why?: Most (all?) outboards use aluminium alloy for the engine block - to keep the weight down. If the outboard is used regularly, there is no real chance for corrosion to develop, BUT... if you use the boat a lot and don't flush afterwards and then for unplanned reasons don't use it for an entire season or so, the salt residue gradually closes up the cooling passages so that next time you start 'er up she overheats.. and warps.. and your day out on the water goes downhill from there.
post #10 of 11 Old 07-27-2012
I would nearly agree with tommays. Most outboard NEVER get flushed, during the season. Unless you never change the oil, its hard to imagine they never get flushed at all. Just to warm up the oil and check for leaks, you have to connect a water supply to run the motor. That's the only time mine gets flushed. At the beginning and end of each season.
Jeanneau 54DS
Flushing your outboard? lapworth Gear & Maintenance 8 05-19-2011 09:00 PM
outboard:freshwater/saltwater MarkCK Gear & Maintenance 3 11-18-2010 12:08 AM
FLushing an outboard RookieHunter Learning to Sail 19 08-09-2009 09:45 AM
Earmuff seal when flushing outboard AdamLein Gear & Maintenance 3 04-05-2009 10:32 PM
No clue re: outboard motor!? Saltwater question! Cony Gear & Maintenance 7 03-13-2004 06:22 PM
