shroud tension - SailNet Community
post #1 of 7 Old 07-25-2012 Thread Starter
shroud tension
Looking for base tensions, upper and lower shrouds on a Capri 30
donWolfe is offline
post #2 of 7 Old 07-27-2012
Re: shroud tension
call Frank Butler
WDS123 is offline
post #3 of 7 Old 07-27-2012
ASA and PSIA Instructor
Re: shroud tension
Just tight enough to keep the mast in column...
sailingfool is online now
post #4 of 7 Old 07-28-2012
Senior Moment Member
SloopJonB's Avatar
Re: shroud tension
Theoretically, standing rigging is supposed to be tensioned to a specific percentage of its breaking strength - obviously this makes it different for every size & type of rigging - wire, rod, galvanized, stainless etc.
IIRC, S/S 1 X 19 is supposed to be 15% of its breaking strength.
Personally, I spent a few bucks for a Loos gauge - that makes it easy to ensure the same base tension on all the stays & shrouds.
SloopJonB is online now
post #5 of 7 Old 07-29-2012
RichH's Avatar
Re: shroud tension
Google Image Result for http://www.tqci.net/~jkriz/Dimensions.jpg
If the mast is single spreader set, provide 3/4" forward mast pre-bow by slightly overtightening the forward lowers and undetightening the aft lowers AFTER initial tension of 15% each. If double spreadered, then 1" forward prebow total - via forward and aft lower adjustment, then prelimarily set all others to 15%, etc. etc. etc. etc. .
Once you get to the 'basic' rig tune..., and If sailing in much more or much less than 15kts ... (above is for normal sailing in 15kts.) then adjust backstay tension as per: http://www.ftp.tognews.com/GoogleFil...f%20Hollow.pdf
For basic mast tuning, once you set up for 15% go to: www.riggingandsails.com/pdf/selden-tuning.pdf .... choose single spreader mast head or double spreader mast head ... and do the fine tuning from there. Seldén's methods are very similar to and are applicable to a Kenyon mast.
FORESTAY tension is THE most important - so the headsail takes on it proper set/shape.
Every day is different so the backstay (forestay, actually) tension is different 'every day'.
RichH is online now
post #6 of 7 Old 07-31-2012
Seaduction is offline
post #7 of 7 Old 08-02-2012
The most female moderator
Donna_F's Avatar
Dock
Re: shroud tension
I'm moving this thread out of the SailNet FAQ forum and into Gear and Maintenance.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
Triple Spreader Shroud Tension Mike36 Gear & Maintenance 12 08-08-2008 11:08 AM
Damaged Shroud SEMIJim Gear & Maintenance 17 10-01-2007 01:44 AM
Shroud Tension Update ktucker8 Gear & Maintenance 5 09-03-2006 11:51 AM
Shroud tension ktucker8 Gear & Maintenance 31 08-29-2006 09:25 PM
Shroud Tension john66 Gear & Maintenance 3 09-17-2002 04:56 PM
