I have to say in all honesty i spray well enough to get paid
1. PPG DCC Concept automotive is the only stuff i ever used that had well defined instructions that were correct in pretty much every aspect
Most auto stuff has a large selection of clearly defined reducers for the spraying conditions that take a LOT of the Voodoo out of it
2. Does Perfection work yes BUT don't even get me started about the BS they put me through during the white recall
3.
Awlgrip rolls & tips nicely BUT its still Voodoo because your working outdoors in and ever changing environment with a
paint that lives or dies on a 5 degree temperature change that you had not put in enough reducer to cover
4.There is NOT enough money in the world to get me to shoot more than bicycle quantity of anything but 545 primer without full blown top to bottom safety gear
All of this stuff
paint or gelcoat when sprayed in large amounts will KILL YOU with a minor respirator screw-up PERIOD
