changing to folding props - SailNet Community
 1Likes
post #1 of 30 Old 07-27-2012 Thread Starter
Can anyone weigh in on folding props. I am considering changing my props to folding ones. Any ideas? Does anyone know a prop supplier who can actually provide support so I don't end up over revving my engines?
Thanks
rackham the red is offline
post #2 of 30 Old 07-27-2012
Junior member, rest old
msmith10's Avatar
Re: changing to folding props
Engines, as in more than 1? What kind of sailing are you doing? A lot of racing or more cruising, daysailing? I wouldn't bother unless you're doing at least some racing.
A folder will help your speed, especially in light air. The sacrifice is less reverse, less drive in big waves (especially compared to a 3 blade).
I went from a fixed 2 blade to a Martec several years ago. Speed better under sail, don't really mind the downside mentioned above. In heavy weather I prefer to sail rather than motor anyway.
Marten can recommend size and pitch so your engine will run at right rpm.
A feathering prop is best all around solution but probably twice the money.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 30 Old 07-28-2012 Thread Starter
Thanks. No racing lots of cruising. I prefer not to use the iron Genoa. I am looking at folding props but before I jumped off and spent the bank I really wanted some input.
Thank you.
Telesail likes this.
post #4 of 30 Old 07-28-2012
We have a Max Prop from PYI. It is a feathering, not folding prop, but serves the same purpose. Reduce drag when sailing. Even cruising, that extra half knot or so can make a big difference over time.
Personally, I prefer feathering and I've had great experience with Max Prop. It's built like a tank and, as pointed out, will perform better in reverse around the dock. Last year, I must have hit something submerged and nicked the leading edge of one blade. I shipped it to the factory and it came back looking brand new.
The newest models, which I do not have, are even better. You can adjust pitch from outside, without opening the gears. They will help you with the correct initial setting, but sometimes a degree or two flatter or steeper can be better for the motoring you do.
Jeanneau 54DS
Minnewaska is offline
post #5 of 30 Old 07-28-2012
msmith10's Avatar
I noticed a mis-spelling in my post above. The brand is Martec, not Marten. Again, if not racing, I'd spend the money somewhere else (new sail?)
Mark Smith
msmith10 is offline
post #6 of 30 Old 07-28-2012
tommays's Avatar
First and the test data supports it reverse is fine and in my case MUCH BETTER over the fixed 2 blade 12 X 8
It works better because you can have a blade design that does NOT have to comprise blade shape VS drag which is a factor in fixed sailboat props
I do a race and the old 12 X 8 fixed was so small anyway i am hard pressed to say anything was really better with the exception of REVERSE which is now vastly better
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 30 Old 07-28-2012
Thanks
Folding props? Engines? Multiple? You have more than one prop and engine? What kind of boat are we talking about?
If you're racing a folding prop is pretty much a necessity. They'll give you time for a fixed prop, but it won't be enough in light air. This I know from experience.
If you're day sailing I wouldn't bother, unless you've money to burn and/or you really want to get the most out of the boat just because you can.
If you're a cruiser I'd think twice. Yes, it will help performance--otherwise racers wouldn't use them. But they introduce complications and another point of failure. Many cruisers spend a lot of time motoring, and some of that time is because conditions are too adverse for sailing. Not a good time for prop misbehaviour. Many cruisers also spend a lot of time maneuvering in unfamiliar anchorages and marinas. Again: Not good times for prop shenanigans. Many cruisers go with feathering props, rather than folding, or stick with fixed props.
The prop companies will recommend a prop (or props) for your boat, depending upon boat, engine(s), etc. I just had both Gori and Flexofold spec props out for Abracadabra.
For a folding prop I'd go with Gori, I think. For a feathering prop: The Max-Prop is pretty much regarded as the best, but a lot of cruising sailors swear by the Kiwi.
We race and day-sail. Some day we hope to cruise. We had a Martec on the boat, but were not pleased with it, so the fixed prop is currently fitted. Next spring I hope to put a Gori on. We were considering a feathering prop, but our normal sailing grounds are very weedy, and one of the advantages of a folding prop is less snagging of things in the water.
Jim
SEMIJim is offline
post #8 of 30 Old 07-28-2012
ASA and PSIA Instructor
Ditto MaxProp from PYI, first class gear and service and without compare.
sailingfool is offline
post #9 of 30 Old 07-28-2012
Moderator
Jeff_H's Avatar
I am a big fan of the Martec folding props having had quite a few of them and found them simple, reliable and not dependent on wildly expensive proprietary zincs.
Gori is the worst prop I have ever experienced. I would never own another Gori. While beautifully machined and cleverly designed, they have an absurdly high failure rate, require wildly expensive proprietary zincs when used with a sail drive, and have miserable, bordering on non-existent product support.
My understanding is that Flex-o-fold has similar issues, but that came to me second hand and was only based on one owner and his description of other owner's with similar problems.
I like feathering props in a lot of ways, but they require more maintenance and often rely on proprietary zincs as well.
I assume the OP's plural on 'props' means that this is a catamarran and so may also have out drives, potentially making prop choices way more limited.
Jeff_H is offline
post #10 of 30 Old 07-28-2012
I don't discuss my member
Fstbttms's Avatar
Originally Posted by Jeff_H View Post
Gori is the worst prop I have ever experienced. ...they have an absurdly high failure rate.
Please describe these alleged "failures." I have never heard of a problem with Gori products.
My understanding is that Flex-o-fold has similar issues.
Again, I have never heard of any issues with Flex-O-Fold. Both these products are robust, well-engineered pieces of equipment, IMHO.
You sound like a guy with an ax to grind.
Fstbttms is offline
Info on Martec folding props? sailstoo General Discussion (sailing related) 2 08-19-2009 07:46 PM
Folding Props for 387's Tusitala2 Catalina 1 08-23-2007 03:20 PM
Fixed vs. Folding Props: How Much Difference? SEMIJim General Discussion (sailing related) 16 07-15-2007 01:51 PM
Feathering and folding props FredSprigman Gear & Maintenance 3 09-08-2001 06:21 PM
Folding Props...Advice/Experiences? halyardz Gear & Maintenance 3 08-15-2001 12:10 PM
