Old 07-28-2012
WattsIsland is on a distinguished road
Wheel Brake
OK folks, I have searched the web and the forums and I don’t find much to help.
I have purchased an Island Packet 26, an old one, hull #9. It has wheel steering that is direct drive to a quadrant. It has never had a wheel brake and I want to fit one, for obvious reasons when single handing.
Has anyone ever made a brake for a one inch steering shaft? I see the ones fro Edson that cost a small fortune for not much and it seems that fabricating one can’t be that hard.
I could use any suggestions.
Thanks.
  #2
Old 07-28-2012
Minnewaska will become famous soon enough
Re: Wheel Brake
I've tied more than one wheel pin off to a nearby grab rail, as a brake. In fact, I could swear my last bareboat charter had a small line permanently attached to the side of the helm for this purpose.
Jeanneau 54DS
  #3
Old 07-28-2012
Re: Wheel Brake
Thanks - A tie off works but I also like the ability to dampen (but not fully stop) the steering action in following seas etc. A synch around the steering shaft would also help but I was looking for an actual braking collar set up of some type.
You may post attachments
You may edit your posts
propeller brake ? jobi Gear & Maintenance 30 07-15-2010 04:16 PM
brake winch ? sealover Gear & Maintenance 4 06-05-2010 06:35 PM
Wheel brake - what the heck is it for? garymcg Gear & Maintenance 10 11-09-2007 05:23 PM
Boom Brake KIKO Gear & Maintenance 0 03-17-2002 03:39 PM
prop brake rdt123 Gear & Maintenance 1 10-17-2001 12:23 PM
SEO by vBSEO 3.6.1
