Conversion to Keelboat - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 08-02-2012
Re: Conversion to Keelboat
Well if it helps Richard, a Centerboard (AKA swingkeel) will be far less efficient than a drop bulb keel, but is just as adequate on a non- sporty boat. It will take up much more interior space, and will be difficult to secure in the down position. It is also far more difficult to make IMHO. It will kick up if you hit bottom that is probably its only advantage.
The drop keel can be easily constructed in a way that it won't slip up into the slot unless you release it so if you turtle it can easily be secured and won't slip back into the case.
250-400# seems like way too much lead for a ballasted dinghy with a deep bulb keel. That i-550 is 18' long, 880# displacement with a 160# bulb. You should be aware that there is an argument against ballasting any dinghy, in that sometimes performance really suffers due to the extra weight, and proper crew placement can be more effective than a proper keel on these small boats.
peterchech is offline
post #12 of 12 Old 08-02-2012
Here's my boat: CHALLENGER 15 (FORD) sailboat specifications and details on sailboatdata.com
It was all pretty much "guess work". I looked at how much ballast was in other similar sized boats and figured it was worth a try. I am very happy with how it turned out even if the boat doesn't get up and plane as easily as it used to. Its so much easier to handle when the wind picks up and makes me feel a lot more confident in rough conditions. I pretty much always sail solo, so there isn't any crew to move around for balance other than myself.
Tom S.
O-Day 22
SchwarckT is offline
Realistic to get my first keelboat for under $10K? aaronwindward Boat Review and Purchase Forum 38 09-21-2010 05:33 PM
moving a keelboat AllThumbs Boat Review and Purchase Forum 1 08-12-2008 07:28 PM
Searching for first keelboat pbf00t Boat Review and Purchase Forum 20 04-13-2006 11:21 AM
Hydrohoist a Keelboat? dchew Boat Review and Purchase Forum 2 08-27-2001 08:18 AM
Hydrohoist a Keelboat? dchew General Discussion (sailing related) 0 07-05-2001 11:35 PM
