Marine Head Issues - Page 2 - SailNet Community
 6Likes
post #11 of 32 Old 07-31-2012 Thread Starter
Re: Marine Head Issues
Thanks for the responses...I'm somewhat pleased to see that it is likely the pump, and not a clog somewhere in the lines...I have only had the boat for a few months, so I cannot comment on the status of maintenance/upkeep by the previous owner. I considered replacing the whole unit, but replacing the pump assembly with a new one - not rebuilding the same pump, but replacing with a pre-assembled one, seemed cheaper. I believe it was $65 or so...hopefully that will do the trick.
However, since it won't be till this weekend until I am down on the boat, I'll be wondering all week how it will turn out...
nolesailor is offline
post #12 of 32 Old 07-31-2012
Jetexas's Avatar
I spent $80 to rebuild the head on my boat once. It didn't seem that horrendous since nobody had used it in years. Six months later with lots of use the toilet stops flushing. The bowl is, of course, full of all kinds of filth.
Once again to save a few bucks I dove into that biohazard and took it apart. This time I discovered the metal rod in the pump had rusted in half, and I had to replace the toilet anyway.
Never again. I'm a cheap bastard, but it's just not worth it.
Jetexas is offline
post #13 of 32 Old 07-31-2012
BJV
Originally Posted by sea_hunter View Post
As you and I have posted before, the cost of a Jabsco rebuild kit is nearly a 100 bucks, for a few dollars more, you get a new head complete with an easy re and re, minus all the aggravation. An education doesn't need to be painful.
And a year or two later you can repeat the process. Jabsco heads are great for the occasional weekend use, but dont stand up to constant use. If you sail a lot then recommend getting a better quality head.
bvander66 is offline
post #14 of 32 Old 07-31-2012
Brewgyver's Avatar
Originally Posted by Minnewaska View Post
(snippage)But, from a guy that has done my fair share of rebuilds, fixes and maintenance, I'm becoming a believer in that mechanic's advice. My next go around may be a full replacement and upgrade.
Wow, if I had a Jeanneau 54, I wouldn't rebuild a head, either!
Just kidding, I think replacing it is an excellent option. I'm having some difficulty with the Groco head in my (recently acquired) Cat 30, and I had no idea I could get a whole new unit that cheap.
Brewgyver is offline
post #15 of 32 Old 07-31-2012
Brewgyver's Avatar
I'm a cheap bastard, too, but I do draw the line on the really sh**ty jobs. As for education, I know how pumps, check valves, etc work, so I think I'll opt for replacement.
So, Bvander66, et al, could you recommend a better quality head? Appreciate it!
post #16 of 32 Old 07-31-2012
Jetexas's Avatar
After my toilet incidents, I was fed up with the crappy plastic stuff, so I went to my local resale shop and bought this rebuilt cast iron beast for $200.
Wilcox Crittendon Junior -- It will flush ANYTHING, and I'm at one year with no issues.
Unfortunately, my sewage lines rotted out and started filling my bilge this summer , but that was an entirely different issue.
Jetexas is offline
post #17 of 32 Old 07-31-2012
Did I mention I work in the waste water industry? Rebuild a marine head, hah, that's not even a warmup for some of the stuff I have to work on!
I guess my viewpoint is a little different.
Gary H. Lucas
GaryHLucas is offline
post #18 of 32 Old 08-01-2012
Then again, all of your problems might be clogged hoses and the iniquitious joker valve. Close hull valve, remove hoses, check for salt/urine buildup. over time these hoses will become throughly clogged. replace joker valve. You can replace the entire toilet however that won't teach you anything.
maru657 is offline
post #19 of 32 Old 08-01-2012
Stu Jackson's Avatar
The choices are pretty simple.
1. Rebuild
2. Replace in kind (same toilet)
3. Buy a good one, like the Raritan PHII, or PHC.
4. Replace your pump assembly with a Raritan LBA which is just the base and pump and you reuse your old bowl
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #20 of 32 Old 08-01-2012 Thread Starter
I am going the replace pump assembly route, but with the replacement Jabsco pump. The next go-round (which I'm sure will inevitably occur) will involve replacing the whole head and upgrading to a better unit.
I've seen in some other threads/posts that a Raritan unit has the same footprint as the Jabsco compact, thereby avoiding the need to drill new holes. Can anyone comment as to whether this is true?
Head issues Domknotty Gear & Maintenance 3 07-05-2011 12:02 AM
Head issues Kiltmadoc Gear & Maintenance 13 08-10-2010 10:38 PM
xantrex freedom marine 1500 inverter/charger issues ncstatesailor Gear & Maintenance 1 04-09-2010 07:57 PM
Help With Marine Plumbing / Fresh Water Issues Koru Gear & Maintenance 3 02-12-2008 04:01 AM
Using a Marine Head Dan Dickison Gear and Maintenance Articles 0 08-14-2002 09:00 PM
