"Rubberize" base of Propane tank(s)? - Page 2 - SailNet Community
 3Likes
post #11 of 21 Old 07-31-2012
Jetexas's Avatar
Re: "Rubberize" base of Propane tank(s)?
You could always just stick it in one of these. Then you can even exchange the tanks when you need refills.
Lite Propane Tank 20lb at NRSweb.com
Nevermind. That's an entire tank. I swear I've seen similar slide on covers for the metal tanks, though.
Jetexas is offline
post #12 of 21 Old 07-31-2012
Old enough to know better
Originally Posted by jimrafford View Post
POR15 will do the job.
Jim
The problem with undercoating is that it never really dries. You will end up with nasty tar like stains on what ever you set the tank on. POR15 will really do the trick. it is basically and epoxy paint, and is available in small containers as well. So one can will do a couple of tanks, and perhaps a few other things too. It is very tough and good at preventing rust. Not sure how it would effect getting the tank re-certified when the time comes. They may not allow repainting, I am not sure about that. I am sure they would not like a thick tar like paint that would prevent you from seeing the rust.
miatapaul is offline
post #13 of 21 Old 07-31-2012
Jetexas's Avatar
What about just setting them in something like this?
3 gal. Nursery Pots (10-Pack)-VHPP300-10 at The Home Depot
Jetexas is offline
post #14 of 21 Old 07-31-2012
Don't you have composite tank's "over there"??
They are lighter, and won't rust... Ever..
Jgbrown likes this.
Somekindofaviking is offline
post #15 of 21 Old 07-31-2012
No composite tanks available in the size that fits my locker, I'm afraid.
MarkSF is offline
post #16 of 21 Old 07-31-2012
Too bad that composite won't fit.....
I know that most sailors "over here" have switched to composite, because of they don't rust/corrode...
You might consider Plasti Dip for coating your existing tank's...
Coatings and Adhesives, Rubber and Plastic Coatings | Plasti Dip Interntional
post #17 of 21 Old 07-31-2012 Thread Starter
F15EWSO's Avatar
All,
very good ideas. The POR15 seems to be the RollsRoyce of coatings, the wound tank is another good idea but right now I'm hemorraging cash on this new boat so the BRILLIANT idea of a pot from the garden center is the way to go; suspect less than $5. I may just have a bottom from one of my wife's current pots that will do nicely. It's all going into storage in 4 weeks so I'm about recycling home products right now.
Thanks to all for the great links and good ideas.
Jetexas likes this.
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #18 of 21 Old 08-01-2012
jppp's Avatar
First I bought a 10# fiberglass tank. Love it but.....need a 5#'er. So I bought a new 5#'er and started applying coats of plastidip, The stuff you dip your tool(stop right there!) handles in. But I felt it would wear through. Bought door edge guard trim at the auto part store. Cut to length. Fits tight and keeps tank edge off the boat. No more rust.
Jetexas likes this.
1985 C&C 35 MK 3
jppp is offline
post #19 of 21 Old 08-01-2012 Thread Starter
F15EWSO's Avatar
Door edge guard, very nice. I'll have to look at my tank and see the finish of the base if it has a rolled edge or not. The door edge guard may prove neater than the simple pot base. The latter holding water (even with the pre-made holes in these) and not being the "exact" diameter. Suspect there would be a length of edge guard left over to tuck away for replacement sometime down the road....
THanks
F15E_WSO + 1
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #20 of 21 Old 08-01-2012
The problem with applying coatings is what may be happening UNDER the coating. In order to avoid that, I'd suggest just cleaning the tank, applying a couple of coats of a durable paint, and then placing a rubber pad in the storage compartment to prevent any more wear.
With a 20# tank (which seems to be 17# under the new math) you are likely to be swapping it out, not refilling it, at some point. Which also means you won't have to pay for tank inspections. Better to leave them naked, or add some more plain white paint, and avoid issues there too.
hellosailor is offline
Tanzer 26 - "Starter" or "Build like a tank" asdf38 Boat Review and Purchase Forum 5 09-24-2016 08:09 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Lumen rating Dr. LED "Sidekick" LED bulb E26 base erps Electrical Systems 9 07-31-2012 05:52 AM
Seacock Base for 1/2" thru-hull "pipe" DrB Gear & Maintenance 2 12-08-2008 01:28 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
