How often do you take your mast down? - Page 2 - SailNet Community
post #11 of 12 Old 08-02-2012
DrB
Every 2 to 3 years
We pull ours every 2 to 3 years for inspection and work. It is expensive to do, $600, but this year we are painting the deck, so it will be needed. The owner before me pulled it every year so that he could store his boat in his yard.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #12 of 12 Old 08-02-2012
Seņor Member
PorFin's Avatar
Re: How often do you take your mast down?
I've pulled the mast on our boat twice: Once to get through the Erie Canal; and the second for indoor storage the year we spent on Lake Michigan (and left it down for the trip down to Mobile Bay.)
When we pulled the stick to do the Erie Canal, I had to cut the VHF and lighting cables (the original install hadn't really been done with foresight) so those had to be fixed before we restepped in Buffalo.
While I had it down for the winter, I cleaned and waxed the spars (it's an anodized Al rig), rebuilt and reinstalled the windex, installed a wind instrument sender, replaced the spreader boots, and a bunch of other stuff that's waaaaaaay easier to do standing on the ground than hanging from a bosun's chair.
I'm in no hurry to pull it again, since there's no compelling reason to do so. Like DrB said, it's not exactly a cheap or easy thing to do, but mostly that's a function of the size and type of your standing rigging.
PorFin is offline
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
Mast leaks on keel stepped 52' mast mikeedmo Gear & Maintenance 5 06-27-2006 01:05 PM
